From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Originally Posted by grbrown
hoggy05 asked for a math guy to give him the speed his bike is doing at 3,000rpm. As an engineer I use applied math and it was too tempting to give him the answer as a math equation! Iron Butt has correctly identified the tyre diameter and gear ratio.
It's the weekend after all, time for a little fun!
Hey guys, nobody mentions the loss by friction between asphalt and rubber
A normal value is 3% depending on grade of incline and wind. 3,000 RPM is 129 KM/H on my GPS
My nephew is mathematically challenged. I told him to try logic instead of math. He asked me what I meant. Well, supposed the problem is "What's 80% of 375?" You could do it by multiplication, or you could say: "10% of 375 is 37.5, so 20% is 75. 375 - 75 = 300. See, you're using logic to break it down to the easiest way to solve it.
In this case you could use math to figure how how fast the wheel is turning for a given RPM and gear size, then factor in things like tire pressure, temperature of the road surface, aerodynamics, etc.
Or you could use logic and look down at the speedometer.
Considering your post location it looks like incline and altitude has a little to do with this answer.
Now, as an engineer I was always trained to show my workings clearly and documented.....
But it's the weekend!
Originally Posted by X Iron Butt
If I come to the UK and Dunlop spells it tyre I will spell it tyre. Over here Dunlop spells it tire so I will follow. Try looking up a tyre shop in our yellow pages and you won't find it. I didn't do it it happened before my time I still spell it colour sometimes.
Dunlop was originally a British company old chap, so of course they spell it correctly. However they also have a translation service for overseas markets......
Interestingly Avon spell it correctly on their US website!
Saw that, but only saw a row of numbers, not confirmation of what each was, apart from the pi constant which is clear. Silly me :-)
Whoa! Somebody say something about pie? I admit, I got lost at the bakery when all that math was being bantered about. But pie, that is something I can really get my hands on. Are we talkin apple, cherry, peach or whatever? There is no such thing as bad pie.
