95 vs 103
Old Jan 2, 2007 | 05:13 PM
swomack's Avatar
swomack
Default 95 vs 103
Some people have said their numbers for a 95" build are similar to a 103". Most of the 95's want 100/100 or better. What does a 103" build get you?
Old Jan 2, 2007 | 07:05 PM
maineultraclassic's Avatar
maineultraclassic
Default RE: 95 vs 103
About $3000 lighter in the wallet.
Most people stick to 95" since it's an easy upgrade. If you go to 103" you have to split the cases and replace the crank assembly. It is a lot more work, a lot more money, but in the end you will get more power.
Steve
Old Jan 2, 2007 | 07:24 PM
swomack's Avatar
swomack
ORIGINAL: maineultraclassic
Steve
How much more power? 20% 30%???
Old Jan 2, 2007 | 07:38 PM
Harleypaw's Avatar
Harleypaw
06 model, I get 118 hp/tq , find you a good after market builder and you'll get it done for around $5000 on 06 and older, a lot less for 07 models.
My dyno chart is in the Dyno section shows cams, pipes, etc.
What ever you decide do it right the first time, it really gets expensive going back
Old Jan 2, 2007 | 07:46 PM
jeepster09's Avatar
jeepster09
I don't think the cost gets you a good value for your money. My 95 makes more power than a lot of 103's and cost substantially less. To make mine a 103 I would possibly only gain 10% more power at a cost of about an additional $3000.00 to do it right.
Old Jan 2, 2007 | 07:57 PM
Harleypaw's Avatar
Harleypaw
Yea but Jeepster you have to admit, not very many 95" have the hp your putting out, most cases 95" build will be in the 100/100 range
Old Jan 2, 2007 | 09:47 PM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: Harleypaw
Exactly.........
Old Jan 2, 2007 | 10:04 PM
103FLHX's Avatar
103FLHX
Very well built 95's will be 100/100. Most aren't. It is not a given. There have been a number of threads chronicalling 95 builds, such as NoGood & Maine & 90ish hp & Torque seems to be very good. Gertting 100/100 out of a 95 motor is not easy.
103's will add more power, but the labor is much more, with splitting of the cases. The performance improvement is smaller than the jump from 88-95. As with high performance cars, the initial improvents are cheap, comparitively. When you are already fast, then next steps are costly, for small gains.
MHO
[sm=icon_guiness.gif]
brnew
Engine Mechanical Topics
56
Sep 29, 2021 08:20 PM
paul0311
Jul 31, 2015 09:17 PM
Spider0408
Jan 29, 2015 02:43 PM
EasyG
Sep 26, 2009 09:47 PM
harris48cars
Oct 2, 2007 12:18 PM
