Auto Tuner
Old May 1, 2012 | 09:00 PM
KennyB1964's Avatar
KennyB1964
Stage I
Default Auto Tuner
Any thoughts on auto tuners for new exhaust? I was recommended to use an auto tuner versus a power commander. Thoughts?.
Old May 1, 2012 | 09:05 PM
madhunter60's Avatar
madhunter60
thundermax, just installed one on mine yesterday, bike runs good, still have a little tweaking to do as the tuner makes adjustments
Old May 1, 2012 | 09:07 PM
2black1s's Avatar
2black1s
You can use an AutoTune with a Power Commander. What exactly was it that was recommended to you, and by whom?
As stated, your question doesn't make sense.
Old May 1, 2012 | 09:40 PM
V2Evo96's Avatar
V2Evo96
I use the RevPerformance EMS tuner. Plug and play although you have to send your factory ECM to them for tweaking. Once you reinstall it it does the rest.
Also RevPerf states that you can make changes such as different cams, headwork, etc up to a 20% power differential without having to send your ECM back for tweaking.
I am very satisfied with mine after switching from the SEPST. It eliminated decel pop I couldn't remove and the bike runs fine from cold start.
Old May 2, 2012 | 11:58 AM
Gearhead3's Avatar
Gearhead3
You can run the PCV by itself or in conjunction with the Autotune. You can't run just the Autotune without the PCV. The Autotune operates through the PCV and adjusts the tune as needed.
Read more here: http://fuelmotousa.com/pcvharley.htm
HDJOE60
2014-2024 Touring Models
81
Apr 3, 2015 02:23 PM
baloot-boy
Oct 3, 2014 02:07 PM
wilburbill
16
Jul 22, 2013 05:21 AM
fuelmoto
Fuel Moto / Jackpot Mufflers
Feb 7, 2012 10:03 AM
Jessie
Mar 8, 2009 05:48 PM
