Can i get some suspension definitions?
Old May 4, 2012 | 02:30 PM
skully1200's Avatar
skully1200
Default Can i get some suspension definitions?
Looking at upgrading both ends of my bike and just looking for a little clarification. Basically, from what I gather, travel is distance from fully extended to fully compressed. Compression is getting shorter, rebound is getting longer, damping is the rate at which these events occur. What I keep seeing that I don't really understand is sag. What exactly is the definition of sag? How, if at all is it related to preload? Sorry if this is dumb, but I need to know and I don't. Thanks.
Old May 4, 2012 | 03:47 PM
qtrracer's Avatar
qtrracer
Sag is how much the suspension settles and there are 2 types of sag, unloaded(bike weight only) and loaded with rider. Sag will be effected by preload and spring rate. If you have to screw in too much preload to achieve correct sag with rider aboard this may make the unloaded sag too little, and that means the spring rate is too soft. If the spring rate is too high you will have to unscrew preload when loaded with rider to get the correct sag and this will make the unloaded sag too much. This is a very basic description and I'm sure someone else can do a much better job of explaining sag than I can.
Old May 4, 2012 | 04:06 PM
grbrown's Avatar
grbrown
Wink
Not dumb, so pleased to help if I can.
Travel is as you describe, fully extended to fully compressed - in other words when the suspension cannot get any shorter! Sag is the amount the suspension compresses, from fully extended to when you sit on the bike when it is stationary. The optimum is one third of total travel. That gives 2/3rds to absorb bumps plus a third to cope with potholes!
Preload is compressing the springs to get the sag right, so they resist the weight of bike and rider. On some shocks there are 2 or 3 positions of spring pre-load, while a few offer much finer adjustment. Not many forks have pre-load adjustment.
Damping is what stops the springs bouncing out of control. If the springs were left on their own, when they hit a bump they will compress, then extend and continue doing that several times before settling down. In other words they would pogo along and make us seasick! Damping limits how much the springs can move and getting it right is a black art.
Hope that helps.
Old May 4, 2012 | 09:00 PM
hdsuspension.com's Avatar
hdsuspension.com
Former Sponsor
Why do you feel you need to do both ends?
Old May 4, 2012 | 10:18 PM
skully1200's Avatar
skully1200
So when measuring to set sag if my end measurement is with me sitting on the bike, what is my starting point? Is it from the point where it sits with the weight of the bike on the suspension, or is it from the bike jacked up with the wheels off the ground?
I'm having a hard time wording the question, hopefully someone understands what I mean.
Old May 5, 2012 | 03:40 AM
grbrown's Avatar
grbrown
Talking
I sorted out my rear suspension, which made blindingly obvious how bad the front is. I suspect many owners find that out the same way!
As qtrracer wrote, there are two sags, however the one that is important is when you sit on the bike, measured from fully extended, wheels off the ground. If you ride 2-up most of the time, measure sag with both of you on the bike. That can be fun unless there is a third pair of hands!
Old May 5, 2012 | 11:54 AM
qtrracer's Avatar
qtrracer
Starting point is no weight on the suspension, so it would be letting the bike down till the rear tire touches the ground but no movement of the rear shocks and measure from the ground vertically up to the upper rear shock bolt. Then the next measurement is the full weight of the bike on the suspension, measuring the exact same way as before. Next is with the rider aboard. All 3 values are important for different reasons.
Vision
2014-2024 Touring Models
Mar 16, 2016 12:40 PM
KumaRide
Nov 8, 2015 09:22 AM
parabellum_9x19
Oct 11, 2013 02:31 PM
baka1969
Sep 8, 2013 07:16 PM
Oakster
Jun 27, 2007 10:25 PM
