CAT removed from header
Old May 5, 2012 | 08:37 AM
Bcun10t's Avatar
Bcun10t
Have not noticed anything at all. However don’t have many miles yet. Seems that there is less heat and I can use 6th gear better. I would say probably no difference in power and only a little bit louder than with them in. I was surprised on how little the sound difference was…
Also I cut the pipe in the center of the CAT and than removed it. Had it welded back together for $25 bucks. Is it worth it??? Not sure however I think the difference in heat will make it worth it..
Old May 5, 2012 | 08:45 AM
mrjimbo's Avatar
mrjimbo
I removed mine at 3500 miles, I'm at 38K now with no problems.......
Old May 5, 2012 | 08:53 AM
Geezr Glidr's Avatar
Geezr Glidr
Originally Posted by Str33tgl1de
How are you guys getting rid of them? Gutting them or just cutting them out and adding a piece of pipe?
I'm not a mechanic, and I don't wrench on my bike, so I didn't cut it out. Got rid of mine by putting different headpipes on. I did Vance & Hines Power Duals.
Old May 5, 2012 | 09:55 AM
reesestewww's Avatar
reesestewww
Here's one option, see signature.
Old May 5, 2012 | 11:27 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Originally Posted by Geezr Glidr
No difference in mileage. #1 reason I got rid of mine (2011 Limited Ultra), was to get rid of that terrible extra heat.
I did the same on my 2012. The cat was cooking my wifes left foot. Since the change I have seen no diference in MPG, but a huge difference in heat. That has made for a very comfortable and happy wife.
Old May 5, 2012 | 02:08 PM
TUCCI's Avatar
TUCCI
Originally Posted by Duc
Are the O2 sensors on a 10 right on top on each other like the 11-12's?
Asking because I keep hearing crosstalk conversations and am wondering if anyone is having issues.
Clif
Mine are right on top of each other (mind you the chamber is partially divided in header) and Ive never had anything that resembles cross-talk....My opnion.... but I think that term is made up JMHO
Old May 5, 2012 | 02:12 PM
TUCCI's Avatar
TUCCI
Originally Posted by skratch
i've put on over 25,000 miles since removing my cat. no noticeable difference in mpg (that can be atttributed to that)
plus: sounds better/louder, much cooler
minus: haven't found any yet.
i just had my bike dynoed by jamie at fuelmoto. he said he experienced no problems tuning my bike. if there was any cross talk, i would think that it would be quite evident on a dyno.
There ya go....finally someone whose had a dyno by a reputable tuner with no data to substantiate the phenomenon....
Old May 5, 2012 | 02:14 PM
TUCCI's Avatar
TUCCI
Cutting it out and sealing it shut (no added pipe).
Old May 5, 2012 | 04:33 PM
dohadex's Avatar
dohadex
What is this BS about cross talk on 2010 above O2 sensors? They are 1" apart!!!
Old May 5, 2012 | 05:11 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Check out where the O2 sensors are in this pic of my 2010 header:
They are positioned before the CAT, and seem to be far enough apart to be well within their respective exhaust flow chambers. I don't see why removing the CAT would contribute to a problem (crosstalk) that apparently does not exist in the stock configuration.
And besides, most folks disconnect the O2s anyway when they do a stage one or other tuning. They go away from closed loop to an Alpha N, throttle position type of world.
As for the restrictiveness of the CAT, many have talked about their impression of just how much the CAT restricts flow. Some say not much, some say a lot.
I performed some exhaust velocity measurements with my air flow meter using my stock header with the CAT, then compared that to the Fuel Moto Stainless Header. Both tests were using the Jackpot Pro-Touring mufflers. Both tests were at cold idle at an rpm of appx 1100-1200.
With the stock header, including the CAT, the right muff exhaust velocity was 19 MPH (speed of the exhaust exiting the pipe) and the left was 9 MPH.
With the Fuel Moto header, the right muff exhaust velocity was 29 MPH and the left was 23 MPH.
I wish I could have measured a catless stock header pipe, but I would expect the results to be pretty close to the Fuel Moto header exhaust velocities.
Measured sound between the stock header with the CAT and the Fuel Moto header was (at idle) 81.5 dB and 84 dB respectively.
Anyway, that's some measurements I took for my own edification to see what the difference was with the stock header versus the FM header. YMMV
