Where's the logic?
Old May 9, 2012 | 09:26 PM
skully1200's Avatar
skully1200
What is the significance of the valve stem being on the right side? I know mine used to be, but when I had new tires put on the wheel must have got turned around as the stem is now in the left. Tire rotation direction is correct. I never looked at the rotors but I will when I get home. Is this valve stem thing something I need to have corrected?
Old May 9, 2012 | 09:41 PM
jberg's Avatar
jberg
Stem on right makes sense if you consider lean on side stand. Seems the confusion "stems" from tire changers confused by the rotor swap.
Old May 9, 2012 | 09:46 PM
Recycled's Avatar
Recycled
It is just easier to get a tire chuck or a gauge on the valve stem if it is facing the highside (right side), while on the jiffy stand. If you don't have a problem working from the lowside there is no need to change it.
snailhouse_projects
Jun 3, 2016 12:16 PM
ubreal
Jul 23, 2012 04:27 AM
upstate tim
Mar 16, 2011 09:41 PM
Orion1369
Sep 23, 2009 09:14 AM
RideDglide
Sep 6, 2009 01:29 PM
