Accessing tail, stop and brake light signals
Old Aug 1, 2005 | 01:28 AM
jdove's Avatar
jdove
2nd Gear
Default Accessing tail, stop and brake light signals
I plan to install an aftermarket tour pack that has tail, stop and brake lights on a 2005 FLHTI with security. What is the best way to get the needed signals from the factory wiring harness? I would like to do this without permanently changing the harness and as also keep the cost reasonable. I have located a connector under the seat that goes to these lights.
Will there be an issue with the security system or the self canceling turn signals? Will I have problems with drawing too much current? I bought this from Ebay for $115 plus shipping. It has a spoiler and looks a lot like the rear end of a Pontiac Grand Am. This ebayer has these listed often and they come in several colors.
Thanks
Old Aug 1, 2005 | 01:33 AM
pilot1996's Avatar
pilot1996
Default RE: Accessing tail, stop and brake light signals
Can you post a pic?
TNW,
Welcome to the forum. I have an '05 FLHTI, and I will be getting a tour pak down the line.
Mac
Old Aug 1, 2005 | 03:18 AM
mikeisglidn's Avatar
mikeisglidn
check under the left side panel you may find the disconnect plug and antena wire in there. good luck and show some pics!!
Old Aug 1, 2005 | 11:12 PM
JDean's Avatar
JDean
Ckeck the J&P Cycles website at www.jpcycles.com. I bought a harness that goes between the connection under your seat and is made for wiring up a trailer connector. If you are not planning on pulling a trailer, I would buy this plug-in harness and wire up to your tour pak. The cost is around $40.
Bdhouse61
Jun 11, 2018 07:02 PM
Whiskyjock
Oct 21, 2017 08:01 PM
hillcountryflt
Aug 14, 2014 07:32 AM
toyz2
Screamin Eagle CVO Models
Jul 19, 2013 06:55 AM
buckwheat
Jan 4, 2009 09:09 PM
