Experienced HD Riders Please Assist
Enjoy the ride and welcome to the forum!!!
Sparky is right about the lubricants. When I switched to Redline synthetic engine oil on my '04 the valve train noise quieted by about 25%, and the Redline shockproof trans lube really made a difference in the shift quality and noise in my transmission. Smooth, light shifts (snick-snick instead of clunk-clunk) and definitely quieter. I plan to change to the Redline on all three for my RGU at the earliest opportunity.
I have to disagree on the pipes, though. I find the stock exhaust is better suited to a serious touring bike like the Road Glide Ultra. I want a deeper tone but don't want increased sound volume, so I'm going with the Von Braun "Radio Flyers" on my RGU. They are only slightly louder than stock. I've had enough of the "in your face" sound of the true duals w/large baffle mufflers that were on my '04. My riding enjoyment has gone way up with the quieter exhaust. But you have to do what YOU like. Just sayin' as on RGU rider to another.
Also, check out roadglide.org. You'll get a lot of great information specific to the RG.
Welcome to the shark tank!
Mike
---On oil: CVO's get Syn3 (HD Synthetic) from the factory. I've heard people say 103's do also but don't have a good reason to believe it yet. Anyway, if a CVO comes stock with it there is no reason you can't switch to it whenever you want. These bikes do run hotter and therefor more potential for breakdown of viscosity, which synthetics handle better. Synthetic also helps with shifting and finding neutral. I put Syn3 in all 3 holes @ 500 miles. I've thought about some of these other oils that everyone always talks about (Redline, Amsoil, Royal Purple, and Spectro), and I'm sure they are better, but I haven't gotten around to doing the research. I know Harley can't dictate oil brand under warranty but I figured Syn3 would be a better idea if I had a claim.
---Will you be doing your own 1K? If not then address your concerns at the 1K. If so then I'd take it in just b4 the 1K and ask them to take it for a ride and answer your questions. Do it b4 the 1K so they still think they are getting your business instead of being sore that you are a do-it-yourselfer.
Enjoy the bike and welcome!
Oh, and I find some earplugs help out with some of the noises too.
I also went from a Yam (RSTD) to my current 2010 ultra limited, and I have learned that following the instruction in the manual is the best practice.
Except the 1st gear, which will be a clunk noise, I can shift from 1 to 6th gear, literally without a sound. Below is what I have been practicing:
- After shifting to 1 gear, I accelerate the bike up to 2500 RPM, and simultaneously, pull the clutch, release the throttle, and apply pressure to the gear pedal (hook, but not forcing it to change the gear). At some point, the gear will engage (shift) to the 2nd gear smoothly, without any sound. Notice that the bike will slow down as the throttle is released to reduce the RPM. It's kind of like let the gear rolls to the next one by itself. You will feel the gear shifting without a noise. Require to practice a little bit.
- Repeat the above step for other gears at around 2500 RPM, and so on.
- Here is my riding style: the relation between gear and MPH: 1 gear/0-10 MPH, 2 gear/15-25 MPH, 3 gear/30-35 MPH, 4 gear/35-40 MPH, 5 gear/45-50 MPH, 6 gear/>55 MPH
You and I will hear many different opinions and suggestions, but that's what I have ridden my bike for the last 30000 miles, smooth and comfort.
I believe that riding at high RPM will abuse the bike, as I get up to 85-90 MPH with 3500 RPM, and I never rev or need to get up to 4000 RPM, as 90 MPH is way too fast for me.
Good luck with the new Harley and you will love it, as I do!
Also, I really appreciate everyones responses to date. It's nice to know you'd welcome me into the fold so easily. I'll admit I was a little worried about the "Harley Guys" welcoming me that quickly but I've had a nice start to what I plan to be a long lasting relationship with this forum.
Thanks guys (and gals).
. Nuff said.
