Intake Tick!!!
Old May 16, 2012 | 08:05 AM
bagdaddy09's Avatar
bagdaddy09
Default Intake Tick!!!
I just finished my cam install last week (SE255). After I got finished, I noticed an exhaust leak, or so I thought, since I didn't change the gaskets. I swapped new gaskets, and cranked it up. I still had the leak? I got home, started it up, listened, and it's no exhaust leak. I'm running an open Se Stage one Air Cleaner, and noticed it through the intake. I pulled the filter off, and it got louder. I tightened all the bolts, and they were good. If I put a cloth over the throttle body it goes away. What in the He'll could it be??
Old May 16, 2012 | 11:14 AM
journeyman's Avatar
journeyman
I think you can hear the motor noises better through a High Flow AC regardless of what cams are in it.
Did you change both on the same day?
Old May 16, 2012 | 11:57 AM
chrisu's Avatar
chrisu
I have the same cams with a SE Heavy Breather, same noise. Seems to be louder when it is cold but does it all the time. A good friend of mine is a master tech at the local dealership and he told me that the motor sounds are more pronounced with a cam change and that is what I am hearing. He said that they hear it in a lot of bikes. Hope it's not a case of "oh, that's normal", but they didn't do the cams at the dealership and he is a good friend so I've been running it. Been over a month and no issues.
Old May 16, 2012 | 12:17 PM
bagdaddy09's Avatar
bagdaddy09
Thanks guys, I looked it up and kind of put it together that it's normal, but glad i got a little reassurance. I just hate exhaust leaks, and thats what it sounds like.
Old May 16, 2012 | 01:02 PM
mrfikser's Avatar
mrfikser
I have the se255 in my bike and noticed the same thing...I think its just the valves slamming shut....its been a few months and the bike still runs great, so I don't worry about it...
Old May 16, 2012 | 01:48 PM
FX4's Avatar
FX4
Yup I have the SE air cleaner with an open cover too and the same cams. Same noise.
Old May 16, 2012 | 04:27 PM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
I've heard same, between cams and better breathing intake, you're just hearing the motor sounds more is my guess
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Old May 16, 2012 | 07:09 PM
CURTYS06FLHX's Avatar
CURTYS06FLHX
Mine does the same thing with SE204 cams. just breathin deeper and better. Sucking more air in. Mine got louder exhaust side too.
Old May 16, 2012 | 07:33 PM
jfarrar30's Avatar
jfarrar30
555's here stage 1 iintake. Same thing. Was told its intake pulse nothing to worry about. So far so good
Old May 16, 2012 | 08:00 PM
DrPlastic's Avatar
DrPlastic
What you are hearing is the solenoids in the fuel injectors snapping open and closed!
