Voltage Regulator Failure
Old Aug 1, 2019 | 04:06 AM
  #31
assiniboine's Avatar
assiniboine
The regulator might not be properly grounded?
Old Aug 1, 2019 | 12:04 PM
  #32
skinman13's Avatar
skinman13
Originally Posted by seniorsuperglideE8
Install a correct size battery and install the correct regulator from Cycle Electric for your bike. The HD charging will take itself out when one component fails, because it's trying to compensate for what else failed. Cycle Electric makes a great product.
Yes, they do, but they are no better nor worse than MoCo parts. Not that I do not trust Cycle Electric. I have used their parts in the past and they are adequate, but I prefer MoCo parts for critical systems. In my years of experience with start/charging systems, I have found that manufacturer's parts are usually the better choice in the long run.
The start/charge system is a balanced system. A problem with one of the 5 main components (starter, battery, voltage regulator, stator, and wiring) can manifest itself as a problem with one of the other components. I have chased many problems with charging system issues that were caused by a worn starter or bad battery cable or a high compression engine pulling too many cranking amps that strains the voltage regulator and stator/alternator under the recharge inrush when the engine starts. Usually this shows up as battery problems first followed by a failed voltage regulator and eventually the stator/alternator may fail if the problem isn't rectified.
Old Sep 14, 2020 | 10:21 AM
  #33
rrhemi's Avatar
rrhemi
After replacing my voltage regulator with the cycle electric version I notice that when hot at idle my voltmeter can read as low as 12 volts. As soon as the rpm's come off idle it immediately increases to 14.5 volts.
Is this typical?
Old Dec 25, 2020 | 08:41 AM
  #34
jpooch00's Avatar
jpooch00
Thumbs down Ya got that right!
Originally Posted by the1fatman
HD electrical components are sub-standard and that's all there is to say. For dependability, I try to find clone replacement parts from Quality manufacurers anytime I have a HD part failure. It is very sad that HD continues to rape loyal BIG MONEY spending patrons, via their "mutitude of failure prone electrical and mechanical components". Other manufacturers have proven for years that, dependable parts can be used in vehicles as desired. This is no more than HD pounding the colons of their loyal and often unwarey followers.
Exactly right in all respects! The electrical system or charging system(s) have failed at one point or other on EVERY H-D I've ever owned, other than the '15 Limited that I recently sold just before it got a chance to.
It DID fail to start when the guy came to pick it up due to the half assed "security system" being confused by radio interference at the airport where it was stored in a hangar, but I guess that doesn't technically-count since I'd already sold the thing - thank God! We had to push it to a place where the interference wasn't as bad to get it to start. Good thing the buyer had a sense of humor and understood Harley's bullshit electronics etc.
Old Jun 17, 2022 | 11:12 AM
  #35
Radster's Avatar
Radster
6th Gear
Originally Posted by FlyBD5
Pure, unadulterated, weapons-grade balonyum. Thousands more out there are suffering from the problems associated with cheap Chinese crap. Same **** that happens when harvard business school morons get their grubby hands on Made in the USA companies.
I want to know
Old Jun 17, 2022 | 11:41 AM
  #36
Max Headflow's Avatar
Max Headflow
Is this typical?
Sounds like the battery is getting weak.. Generally after starting it will take a while for the battery voltage to get to 14.5. They typically hit about 13.5-13.7V and after a couple minutes go to 14.5.
Old Jul 12, 2023 | 05:18 PM
  #37
sfazekas's Avatar
sfazekas
4th Gear
I'll have to try this with my 2000 FatBoy. I seem to be having the same issue with my charge after I changed the voltage regulator, and I may have to change the stator. That bike has been sitting a long time (I haven't gotten around to troubleshooting the rest of it) b/c I'm riding my other bike (my 2001 FatBoy) whenever I do trips.
Old Jul 12, 2023 | 07:27 PM
  #38
Keithhu's Avatar
Keithhu
Is there a question here?
Old Jul 12, 2023 | 07:52 PM
  #39
sfazekas's Avatar
sfazekas
4th Gear
You got me! Just posting my thoughts on my same/similar situation. Probably no questions till I clean my contacts for my voltage regulator and make sure there's the proper voltage on the battery when I start the bike... I had thought I'd have to take things apart and check the stator connection & ohm response before I tear into it. I have a second bike that does not have a charging problem, so I'll compare the two.
Gregcinhi
Electrical/Lighting/Alarm
13
Mar 11, 2018 09:12 AM
WildCherry
Aug 14, 2017 02:41 PM
jonmerrill
Dec 27, 2015 04:19 PM
FL-kruzen
Mar 28, 2012 06:46 PM
cbaker1@farmersagent.com
Aug 19, 2010 12:36 PM
