Ohlins how do you set the preload?
I talked with howard and went over the numbers and some other things. he has been and will be on the phone with install appointments. anyway it appears my springs are sagging more than the desired 5mm under the static w/o rider measurement as I am getting 30mm of free sag, which by the way is only 1 mm shy of the desired 1/3 #31mm. when mounted on the bike I am getting a total sag of 49mm. He is going to check some stuff out and get back to me.
do any of you have these springs on the #6 shocks? if so how much did you compress your springs too? I have mine at 193 mm right now. they are a 220 mm lenth spring
With the bike off of the ground (he has height adjusters, the length of the shock is longer) from flat to bolt flat, the (R-1) measurement is 372mm.
The length of the shock with only 14 mm of spring pre-load when the owner is holding up his bike and the tire is on the ground is: 11 mm of free sag or (R-2).
The total sag with the owner on the bike is 22.5 mm.
With two people on the bike is 338mm or 34mm of total sag. Thanks MtTobyUltra for the help.
If in fact your measurements are correct (which I have no doubt it is) that there is something I need to look at. You have a 5 year warranty against defects. I will ask Ohlins USA for feedback on this and call you, but most assuredly you can call me after 9:15 ESDT for answers. The spring is what is holding up your bike and not the shocks. The springs overcome gravity as that is their only purpose. The shocks control the movement of a weightless bike. We will get to the bottom of this on Monday so call if I do not call first.
I'll post a full review once the shocks are broken-in, but based on the short ride I took tonight, the ride quality and handling are drastically improved. They will be a little stiff until fully broken in, but even when new they have none of the harshness of the stock shocks. The ride is so much different that it feels like a different bike.
The only surprise during my test ride was that, unexpectedly, they actually made the front end feel a little better. Some of the ride characteristics that I thought were due to the stock forks were actually the fault of the stock shocks. Having said that, the front end still needs a lot of help.
One last thing. It's almost impossible to get decent customer service anywhere these days, but Howard's help, time, and effort throughout the ordering and installation processes was outstanding. He took the time to talk through, in detail, the choice of the #6s, then spent the time necessary to ensure that they were installed and set up correctly. Thanks Howard! Great product and service!
A little about springs and how they work: A 180mm spring has only 113 mm of stroke minus your pre-load. This means that 113mm (-) spring pre-load of 30mm = 83mm (-) 10mm safety = 73mm far less than the 93mm of stroke on your shocks. The spring would go into coil bind before the shock could complete its stroke.
I relpaced the 00380-07/L3911 springs with the aforementioned. And Damn you are up early.
Rear tire off the ground, bolt to bolt measurement: 13.25" or 337 mm
Bike totally on the ground, no rider, no saddlebags, bike held straight up, bolt to bolt: 12.375" or 314 mm
So about 23 mm difference between these two measurements, unloaded versus loaded with no rider and the bike vertical.
Bike with my fat *** on it, 215 lbs, no saddle bags, bolt to bolt: 12.0" or 305 mm
The difference between just the bikes weight on the shocks and my weight on the shocks (no saddlebags) resulted in: 0.375" or 9 mm additional travel.
As measured, I have a total loaded travel of 32 mm (rear wheel in air measurement versus me on the bike measurement) without the weight of the saddlebags which is about 40 pounds (weight of bags and gear inside). Once they are on, there is probably less than a mm of added travel introduced.
My wife helps me with these measurements. It's impossible to measure it correctly by yourself. I wish there was a way to measure it with the bags on just for ***** and grins, but that ain't happening.
Hope this helps some.
