weird Science
2.) prepare for an oil change, you may well have raw gas now mixed with oil- you want to change that before you run the motor.
3.) the pintle in the injector can become stuck through wear or a spec of dirt, it may need replaced. If the injector is fine, but the ecm is telling it to open ( this can be seen by checking with a meter) then you got problems.
mike
Sounds to me like you'll be replacing at least one, but I'd consider both while you're in there.
PO122 TPS open / low
PO 131 Front oxygen sensor Low/lean
PO151 rear oxygen sensor low(lean)
PO 261 Front injector open
PO262 Front injection High
PO263 rear injection open
PO264 rear injection open
P1351front ignition open/ low
p1354 rear ignition open
P1004 system relay contact close ,,,,,,,is this is my only problem ?
pls, somebody help me on the right direction . thank you in advance ..
