AIM users???
Old May 19, 2012 | 10:32 PM
HighLiner's Avatar
HighLiner
Default AIM users???
Does the AIM variable pressure clutch set up fit under the stock 96" derby cover or does it need the spacer? I've seen both yes and no!
Old May 19, 2012 | 11:17 PM
MichiganRider's Avatar
MichiganRider
It should fit. I had this setup on my '02 Road King with a stock derby cover with no problem. Its a great setup, enjoy.
Old May 19, 2012 | 11:38 PM
Pelonz's Avatar
Pelonz
I was told it works without a spacer on stock derby cover. I run a spacer but have a skull derby cover.
Old May 20, 2012 | 01:20 AM
Mike's Avatar
Mike
I have one under the stock derby cover. Adjusting the clutch becomes a little trickier, a offset box end wrench won't clear the vpc. I use a 11/16 deep well spark plug socket. I can put a wrench on the end of the socket and slip a long hex wrench down the middle.
Old May 24, 2012 | 09:43 PM
HighLiner's Avatar
HighLiner
Who has the best price?
Old May 24, 2012 | 09:47 PM
mongomark's Avatar
mongomark
I also have the AIM VPC under my stock derby cover. No problems whatsoever and the clutch operation is great. I also went with the standard clutch spring for a 2003 model big vtwin.
pounder35
Mar 21, 2019 06:24 PM
MachU
Jun 28, 2015 12:56 PM
RKLeo
Dyna Models
Aug 16, 2008 06:03 PM
buckwheat
Feb 11, 2008 06:05 AM
gombul
Exhaust System Topics
Feb 3, 2006 12:36 AM
