**Highest lift cam on STOCK springs**
Old May 23, 2012 | 12:49 AM
Mike's Avatar
Mike
Lift is only one aspect, ramp speeds and cam profile also factor in. It's not just coil bind you're trying to avoid. Valve float at higher rpms is a consideration, as well as bouncing the valve off the seat as it sits back down. I'd pay attention to the mfgr recomendation for springs. Some cams at .590 lift will be fine with stock beehives, others might need stiffer springs.
Old Oct 23, 2015 | 09:16 AM
motolocopat's Avatar
motolocopat
Bump on this for some updated experience since a lot of people have been pushing the limits of stock valve springs over the last few years and some of the builders have become more comfortable with the stockers limits and durability.
So what cams/lift, how many miles have been racked up and how much time is spent at upper RPM's
Old Oct 24, 2015 | 07:33 AM
glide2005's Avatar
glide2005
I have Andrews 54H's (555 lift) in my, well was 96". But I also had 103 head reworked and installed. I now have upgraded my 96" to 103 via 103 jugs and pistons with same heads and cams without issue.
Old Oct 24, 2015 | 09:01 PM
Recycled's Avatar
Recycled
IMHO, a .575" lift is within the reliability/comfort level for the average rider. My 103 with stock heads and ACRs (installed as factory recall in '07), has had the Redshift 575 cams installed for a little more than 35,000 miles now without any issues. Just another improvement made to wake up this bike from its stock configuration.
Old Oct 24, 2015 | 09:52 PM
ROCKOUT Rocker Products
Sponsor
I'm running the 57H @.560 with stock springs... no issues.... '15 Limited Low
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Oct 25, 2015 | 09:28 PM
Darrell07FLHR's Avatar
Darrell07FLHR
Springs are not that expensive and can really help control valve float. If you pick decent springs they can even be reused if you go with larger valves and port the heads.
Old Oct 25, 2015 | 09:37 PM
dawg's Avatar
dawg
43k on redshift 575's with stock springs, no issues
Old Jul 10, 2020 | 06:46 PM
Alexandre Doiron's Avatar
Alexandre Doiron
Stage I
Originally Posted by BLK08ROCKERC
Just as the title states, what is the highest lift you can get out of a set of stock 96" valve springs?? Is say .575 to much?
my roommate has the 585 s&s in his
Old Jul 10, 2020 | 08:06 PM
HD Bobber's Avatar
HD Bobber
When I did my previous bike and I went with S&S 585’s I redid the heads and beefy up the springs. I say below that you should be ok.
add: I would also recommend getting better lifters too while your at it.
Old Jul 10, 2020 | 08:11 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
we have to revive threads from 2012?
