tire dot
Old May 22, 2012 | 09:35 PM
shorty07ultra's Avatar
shorty07ultra
Default tire dot
Been awhile. Where do I put the dot in relation to valve stem when mounting. Thanks in advance.
Old May 22, 2012 | 09:38 PM
HDJIM1158's Avatar
HDJIM1158
I am no tire expert but I thought you put the green DOT at the valve stem.
Be Safe JIM
Old May 22, 2012 | 09:39 PM
Black_Hog's Avatar
Black_Hog
The DOT lines up with the valve stem. It's suppose to be the balance point for the tire.
Old May 22, 2012 | 09:57 PM
old v twin's Avatar
old v twin
Default Tire dot location
While the dot looks best at the valve stem, it appears to me that the dot is a visual reference for the installer to ensure proper tread rotation orientation.
Dot to the intake side on the tires I have purchased.
The unknown variable of wheel roundness / balance, to the manufacture, versus the actual balancing of the tire / wheel combination by the installer, seems to discount the dot having any relationship to the valve stem location.
My 2 cents.
Old May 22, 2012 | 10:04 PM
DresserDude's Avatar
DresserDude
line up dot with valve stem.
Old May 22, 2012 | 10:18 PM
Retrop's Avatar
Retrop
Line em up!
Old May 22, 2012 | 10:23 PM
Black_Hog's Avatar
Black_Hog
I changed many tires, cars, trucks and motorcycles. Worked as a tire changer for awhile. If you line the DOT up with the valve stem, the tire balances better with less tire weights.
Old May 22, 2012 | 11:21 PM
vzts4q's Avatar
vzts4q
The following is from the Dunlop tire site.
7 - Tire Installation (see also Tire Mounting)
Dunlop street tires have balance dots in the bead or sidewall area to indicate the lightest point of the tire. All Dunlop street tires should be installed with these balance dots at the valve. All Dunlop street tires also have arrows on the sidewall, which indicate the correct direction of rotation.
http://www.dunlopmotorcycle.com/info...d-maintenance/
Old May 22, 2012 | 11:57 PM
karbar99's Avatar
karbar99
My 2 cents.
"Dot to the intake side"
I'm lost on this one?
Old May 23, 2012 | 11:04 AM
Roadking Cal's Avatar
Roadking Cal
That actually applies only to the front tire/wheel.
The dot is a painted or inked addition to the tire, and therefore adds to the thickness of the tire in that particular spot. As the tire spins, that slightly raised portion of the tire creates added turbulence to the air stream. This added turbulence flows to the motor's air intake, and helps to make a better air-fuel mixture, therefore, improving engine performance.
I hope this clears up any confusion.
No, really....I looked it up on the internet!
