monotube help!
Old May 26, 2012 | 03:54 PM
allenalee's Avatar
allenalee
Default monotube help!
I need help. Bike is 09 ultra. I removed fork springs and the damper valve. Is there a trick to get the damper rod to fall out? 6mm bottom screw is out. One screw will not come out but is loose. Great way to start the weekend. Thanks
Old May 26, 2012 | 03:59 PM
allenalee's Avatar
allenalee
Bike is an 09 Ultra.
Old May 26, 2012 | 07:12 PM
bagman1's Avatar
bagman1
Did you unload all the tension before you took the bolt out? You also need to use an impact gun otherwise the cup will start spinning and the bolt wont come out.
euchre98
May 9, 2012 08:44 AM
smokey27b
Mar 2, 2012 08:12 PM
shredder22
Dec 7, 2011 12:35 PM
BigSeaDaddy
Apr 4, 2010 10:49 PM
09 UltraFine
Sep 11, 2009 08:52 AM
