ECMs
Old May 28, 2012 | 09:49 AM
$tonecold's Avatar
$tonecold
I couldn't pull up a '10 103 on Harley's website, but the '11's have 9.6:1 static compression. Closing the intake valve at 19 degrees abdc gives you a cylinder pressure of almost 197 psi cold. The map you have loaded has a total advance of 35 degrees. Go into your Thunder-max program download your map from the ecm. On the selections on the left click on ignition timing maps, then timing vs. engine speed. You then need to modify your map in the 2500-3000 rpm ranges, probably take out 2 degrees timing to start. You could probably take out 2 degrees all the way through and not hurt anything. This cam is like having 10.5:1 compression with a normal cam.
Old May 28, 2012 | 02:59 PM
fla23017's Avatar
fla23017
Thanks $tonecold. I'll try that and see what happens.
BOSOXFan
Aug 25, 2015 04:48 PM
skypilot_one
Jun 19, 2014 10:37 AM
thewholehog
Nov 22, 2011 03:56 AM
gedo76
Exhaust System Topics
Nov 12, 2011 10:59 AM
LA VIC
Feb 9, 2011 04:07 PM
