New cams
Old May 27, 2012 | 11:31 PM
HDWG's Avatar
HDWG
Big Kahuna HDF Member
Default New cams
So, got a set of S&S 551 easy start cams S&S adjustable push rods, having a hell of a time getting everything to work. To start had an issue with getting the cam plate/ oil pump back on the crankshaft..a tick out of alignment and snapped the oil pump gear..nicked the very end of crankshaft a very little bit..oil pump slides over it and is behind nick...nick does not appear to be a issue...Looked over the cam plate, see no cracks or, any other issue, no material in case area, new pump..etc..
Cannot get the flippin push rods to stay..Get everything set, hit base, have a click noise to tell me base after passing the compression tab on cam...adjust it basically 3 turns, tighten the hell out of the nut...Fire it up, sounds great, runs great for about 10 miles or so..rods loose, ticking...more ticking, engine shuts down..happened several times...first time rear intake rod, second time rear intake rod, third time front intake rod, fourth time rear intake and exhaust rod..
First time, had to get a new tappet for the rear intake, spring 1/2 popped out.. so far, no more need for tappets..Rods do not look bad..
Adjusted so many times, referred to here, you tube, and random google..I think I got the adjustment thing ok, the tightening of the lock nut..
__________________
Old May 28, 2012 | 07:41 AM
pittz5's Avatar
pittz5
wow, sounds like a project you wish you never would of started. Been there!! ;-) I have the 583ES cam and I havnent heard this "click" you are talking about when I adjust my pushrods. I can only assume you have the plugs out and are turning rear wheel to find TDC compression stroke? It really sounds like your starting from wrong point when adjusting pushrods. Just make sure your at DTC and lifter is at its lowest point and re-adjust. Are your pushrods lock nuts actually loose when you go back to check them when bike dies?? Good luck man, sorry your have all the issues.
Old May 28, 2012 | 09:48 AM
redrub's Avatar
redrub
You are letting the tappets bleed down?
Old May 28, 2012 | 10:06 AM
The Q's Avatar
The Q
I know there are lots of success stories on here about adjustable pushrods, but like you, me and Mr. Murphy have a close relationship. That's why I elected to go through the top when I did my cam swap.
Old May 28, 2012 | 08:51 PM
HDWG's Avatar
HDWG
Getting base, when you hit base, the exhaust rod goes up, click and then goes back down...base off the compression tab..both the intake and exhaust are at the lowest level when I do adjustment..Usually let it bleed for 20 minutes or so, the rods start turning with my fingers with drag..What I have been doing is 4 full turns after I get them somewhat tight with fingers, no up and down movement. Let them bleed..20 minutes and they can be twisted with fingers with some drag, back off 1 turn and goto the other side, find base, do it again.
Old May 28, 2012 | 08:53 PM
HDWG's Avatar
HDWG
Here is the instruction I followed.
http://www.youtube.com/watch?v=n5KvamRqCis
Old May 28, 2012 | 09:05 PM
Iamdent1's Avatar
Iamdent1
This is the same video I used last month installing my brother and my cams. Did two bikes in two weeks with out to many problems. I think the best thing we did was use a drinking straw in the piston we were working on to make sure piston was up and both lifters down to make sure we were on the proper stroke. I sure can't make sense out of the adjuster nuts loosening up. What push rods you using, we adjusted both of ours at 3 turns after taking out the slack in the rods.
Old May 28, 2012 | 09:27 PM
HDWG's Avatar
HDWG
S&S adjustable rods, stock lifters..What is this straw method? I tried that to, take slack out of rods, 3 full tighten turns..are you letting them bleed?
Old May 28, 2012 | 10:04 PM
Iamdent1's Avatar
Iamdent1
We just took a long straw, set it on top of the piston so we could tell when the piston came up and the lifters where both in the down position. Compression stroke. Took two of us to do it that way. Actually have to kinda hold the straw so you can feel the movement of the piston and if ya don't hold it, it will blow the little sucker right outta there. Worked great for us.
Old May 29, 2012 | 11:01 AM
tonyszuma's Avatar
tonyszuma
2nd Gear
there is a very detailed step by step video on youtube, made by jpcycle, very detailed, if you find it it will help
