Rush touring slip-on muffler basic installation guide
Rush slip-ons are designed to mount using stock hardware and brackets.
1. Remove saddle bags for easy access to bolts.
2. Loosen or remove heat shields to allow access to muffler clamps.
3. Loosen muffler clamps. Remove bolts from mufflers and mounting bar at rear of muffler under the bags.
4. Remove mufflers. A little penetrating oil helps greatly and moving mufflers from side to side can help loosen them.
5. Slide new muffler clamps over new muffler inlet (positioning them correctly so they are hidden).
6. Slide new muffler onto headpipe until the rear mounting bosses line up with the rear mounting bar. Hand-tighten bolts to hold muffler to the mounting bar, do not tighten completely.
7. Make sure muffler clamp is over the muffler inlet covering the slots. Tighten until snug but not completely.
8. Repeat steps 7-8 for muffler on other side of bike.
9. Align mufflers for best fit. Tighten all bolts. Tighten clamps to 60 ft-lbs of torque.
10. Re-install saddle bags. Re-install heatshields making sure shield does not contact muffler.
11. Clean mufflers before starting bike. Discoloration due to oils and residues from hands during installation is not covered under warranty.
Basic tuning info:
Please contact Rush for specific recommendations for your bikes setup. This is a simple quick guide.
1. Completely stock 2010-2012 bikes.
b. 2.25 minimum baffle size recommended.
b. Dyno tuning is recommended and usually required for proper operation any time headpipes are upgraded regardless of slip-on muffler or baffle size.
Feel free to post general questions directly to this thread.
-Ryan
I currently have the CAT and 2.50" baffles, no problems and the sound is great. When I get rid of the CAT I plan to go with 2.00" baffles.
Ryan
Ryan
