Odd, problem
Old Jun 3, 2012 | 08:44 PM
JeepMaker's Avatar
JeepMaker
Default Odd, problem
I have a 2007 Ultra Classic, stock except for mufflers and ied's.
I recently noticed something odd. The wife and I were cruising along and I saw that when we would hit a bump, or even a dip in the road, my right turn signal indicator would flash on and off. Only the right, and fairly consistantly, nearly every bump.(and in Toledo, that's a lot)
First thing I checked was the bulbs. All brake lights and turn signals work.
Anyone ever hear of this?
EDIT; BTW, I thought maybe it was a short in the turn signal switch, but with it running I can bang on the handle bars and it won't do it.
Old Jun 3, 2012 | 09:04 PM
txfxstrider's Avatar
txfxstrider
Got to be a loose connection. Banging on the bars apparently is not as hard as hitting a bump or dip.
Old Jun 4, 2012 | 10:14 AM
fordhd2005's Avatar
fordhd2005
I'm not sure about the 07 but on my 09 the wires for the turn signals were in a rubber strip glued to the bottom of the fender right down the center. Part of it had came unglued and rubbed the tire. The dealer fixed it the first time under warranty but it happened again shortly after so I just rewired it to run along the side of the fender.
Old Jun 4, 2012 | 01:28 PM
kfstreetglide's Avatar
kfstreetglide
this same thing happened on my 07
Old Jun 4, 2012 | 03:19 PM
TUCCI's Avatar
TUCCI
Yeah theres a loose connector somewhere.....
Old Jun 4, 2012 | 03:30 PM
CHILLLS's Avatar
CHILLLS
IEDs (IMPROVISED EXPLOSIVE DEVISE) holy cow bat man!! you need to get those off there!!!!
ya...i cant help you but thought this was funny.
Old Jun 4, 2012 | 04:31 PM
mkguitar's Avatar
mkguitar
....Part of it had came unglued and rubbed the tire.
or on a lowered bike the tire can rub through the insulation (or if the tire blows out the carcass can whip around and hit the wiring)
try to isolate the fault front/rear
mike
Tack57
Electrical/Lighting/Alarm
Jul 10, 2018 09:22 PM
texashillcountry
EVO
11
Nov 2, 2016 08:46 PM
FLYSBY
Apr 17, 2012 04:34 PM
the reverend
Aug 29, 2010 07:29 PM
dhellyer08
Mar 18, 2010 02:55 PM
