Turn Signal Issue
Old Jul 8, 2018 | 09:54 AM
Tack57's Avatar
Tack57
5th Gear
Exclamation Turn Signal Issue
I just purchased a 2007 FLHTCU and took it on a trip. On the way home I noticed that the right turn signal wasn't working. Check the bulbs, they were fine, tried the four way flasher and all the lights worked, both the right turn signal, along with the left.
I called the shop and they were baffled. I ended up making an appointment for them to look at it but it will be three weeks before they can get it in. Anyone have any ideas on what I can check before then?
Old Jul 8, 2018 | 05:23 PM
08police's Avatar
08police
My bike just recently did this. I have an 08 Flhtpi. Everything was working fine and left for a ride today and I had no turn signals or break lights. I just rode it the other day and everything was fine. I checked the fuses and relays and everything seemed fine. I am also baffled.
Old Jul 8, 2018 | 07:35 PM
chillymac's Avatar
chillymac
my 07 fatboy just did this same thing no brake light no turn signals, accessory fuse was blown, two days latter did it again.not sure where to start looking
Old Jul 9, 2018 | 08:53 AM
Zanthamos's Avatar
Zanthamos
Sounds like the TSM is in its death throws, I have seen them do this several times just one side not work but the 4 ways work just fine.
Old Jul 9, 2018 | 09:49 AM
Tack57's Avatar
Tack57
5th Gear
I'm new to this and still learning the lingo, what is a TSM?
Old Jul 9, 2018 | 09:55 AM
Zanthamos's Avatar
Zanthamos
Turn signal Module, if you have a HD security system then is it is the Turn Signal Security Module.
Old Jul 9, 2018 | 05:49 PM
ghost183's Avatar
ghost183
go to HD and have them plug it into the digitech.. its the only way to check the TSM if its going bad.. and if you have a handsfree sec system. RUN to HD to check, thats a tell tale its going bad, i just had to replace mine after a lengthy process of illimination
Old Jul 9, 2018 | 10:15 PM
Zanthamos's Avatar
Zanthamos
07 is the push button FOB
Old Jul 10, 2018 | 07:02 PM
wastedranger's Avatar
wastedranger
07 is hands free fob.
Old Jul 10, 2018 | 09:22 PM
Zanthamos's Avatar
Zanthamos
I stand corrected.
Winston74
Electrical/Lighting/Alarm
Feb 17, 2015 06:24 PM
ND01CTD
Mar 22, 2012 02:15 PM
wanabe
Aug 16, 2010 10:30 AM
z28kilr
Apr 14, 2010 11:53 AM
SCS
Oct 17, 2006 08:59 PM
