Modified Cat/ more engine noise
Old Jun 5, 2012 | 08:10 AM
cfave's Avatar
cfave
Default Modified Cat/ more engine noise
I modified my cat and put on V&H Monster Ovals. Heat is GONE and the pipes sound great but, and I dont know if I didnt notice it as much before, but since I made the change there seems to be more engine noise. At idle and when I rev it or when just starting out, it is an exhaust sound that sounds Tinny. Once the but gets going it seems to not be as bad but, just seems louder now after the change.
Anyone know what the hell Im talking about? or am I gone over the deep end?
Old Jun 5, 2012 | 08:16 AM
purple glide's Avatar
purple glide
If you did a stage 1 upgrade with free flowing breather that will make the bike more noisy. When I had my softail I noticed it
Old Jun 5, 2012 | 08:24 AM
cfave's Avatar
cfave
I only did the pipes so far, I am saving up for the rest of the Stage 1 mod.
Old Jun 5, 2012 | 09:19 AM
davidsdad's Avatar
davidsdad
Exhaust leak at the exhaust ports from when you removed and reinstalled your pipes??
Old Jun 5, 2012 | 09:51 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by cfave
...it is an exhaust sound that sounds Tinny...
Loose heat shield?
Old Jun 5, 2012 | 11:07 AM
cfave's Avatar
cfave
I was thinking this too but, I cranked down on the bolts pretty good. Are the gaskets supposed to line up a certain way (opening in the oring)?
Old Jun 5, 2012 | 11:08 AM
cfave's Avatar
cfave
Originally Posted by Pine Tree
Loose heat shield?
Checked them too and they are all tight. It is coming from around the front exhaust port area
Scorpn256
Dec 20, 2011 02:11 PM
rvnkontum
Jun 10, 2010 04:17 PM
ashenfang
Aug 8, 2009 01:21 AM
upnorthbiker
Dec 1, 2007 02:52 PM
shortsport
Jul 4, 2007 09:19 PM
