Oil pressure problem
Old Jun 7, 2012 | 04:45 PM
Bill03E's Avatar
Bill03E
Looks like you got lucky , if it didn't trash the oil pump , I would, get the new hydro cam plate ,and tensioners, which comes with a higher volume oil pump, and some cam bearings at least , and put er back together.
Old Jun 7, 2012 | 06:17 PM
Ultrascott's Avatar
Ultrascott
I've bought the new screaming eagle cam plate w/ new high volume oil pump. I also bought a cam install kit. Time to put it back together and see how it does
Old Jun 7, 2012 | 06:38 PM
Bill03E's Avatar
Bill03E
Can you post a pic of the old oil pump?
Old Jun 7, 2012 | 09:03 PM
Ultrascott's Avatar
Ultrascott
What do you want to see and I'll take some tomorrow
Old Jun 7, 2012 | 09:22 PM
Bill03E's Avatar
Bill03E
The bad spot in the oil pump, just curious how bad it is.
Old Jun 7, 2012 | 09:29 PM
Ultrascott's Avatar
Ultrascott
I doubt it will be clear in the pic. I can feel the scratches with my fingernail. Doesn't look that bad but I guess it's just enough. I'll try to get some
Old Jun 7, 2012 | 09:39 PM
kel03's Avatar
kel03
Look forward to those pics of the pump, tagged to learn. Thanks
Old Jun 8, 2012 | 02:39 PM
Ultrascott's Avatar
Ultrascott
Got her back together. Oil pressure is the most it's ever been. Not to bad of a job overall just tight in a few areas. Thanks for all the info. Here are a few pics
Old Jun 8, 2012 | 02:55 PM
Bill03E's Avatar
Bill03E
Yep that would do it, did you buy timken cam bearings? They seem to last a lot longer than stock ones.
Are you doing the work yourself, or is someone doing it for you?
Old Jun 8, 2012 | 03:00 PM
Ultrascott's Avatar
Ultrascott
I got the cam install kit from the dealer so whatever was in there. I don't think they are though. I did all the work myself. Never tore into one of these motors but had to do it myself plus I like wrenching on my own stuff
