Power issue after radio install
Old Jun 7, 2012 | 10:39 AM
Ricoted911's Avatar
Ricoted911
Default Power issue after radio install
I recently started the install of a biketronics radio kit on my 2010 Ultra Limited. I did everything wiring perfectly but I forgot to disconnect the battery before I replaced the radio and the harness. The bike now does not seem to be powering up the fuel pump, gauges, radio, horn, brake lights, headlights, etc. the only thing that seems to have power is the security system light on the speedometer blinks like it should. I plugged the old factory radio in toto rule out the new radio as the issue, as well as checked all the fuses in the left side fuse panel and disconnect/reconnected the battery. I am kinda out of ideas on what it could be. Any thoughts or ideas would be appreciated!
Old Jun 7, 2012 | 11:41 AM
Guntoter's Avatar
Guntoter
Do you have the security key fob with you when you try to start it? I don't think not un-hooking the battery would be an issue, but you could check that "maxi-fuse" that is in the fuse block.
Old Jun 8, 2012 | 09:56 AM
Ricoted911's Avatar
Ricoted911
I pulled and checked the fuses but still nothing. I think I will replace most of them just to see if one has a hairline crack in the contact. It's gotta be a fuse I would think...
harleyd1500
Audio Systems
Jan 26, 2018 08:43 AM
Bad_Attitude
Audio Systems
Mar 30, 2016 02:17 AM
jallen28145
Aug 17, 2013 12:53 AM
Wanna Ride
Aug 4, 2010 12:17 AM
abreitbach
May 30, 2007 06:38 PM
