Intermittent Check Engine Light
Old Jun 9, 2012 | 12:31 AM
Pog Mo Thoin's Avatar
Pog Mo Thoin
Default Intermittent Check Engine Light
I have a 2003 Road King with 56k miles. Recently My check engine light comes on intermittently and I can't seen to figure it out.
It sometimes come on right after I start the bike and will go out after 30 seconds or less. Other times it will come on when I'm riding at the high end of the rpm range for a period of time and will go off when I back down a bit.
I've also noticed I'm getting some blow by out of the air cleaner.
Recently changed the cam tensioners and oil pump etc but the check engine light preceded those changes.
Any thoughts?
Old Aug 11, 2013 | 04:55 PM
Ranch Rider's Avatar
Ranch Rider
Stage II
I've been having this same problem...does anyone here have an explanation?
Old Aug 11, 2013 | 05:04 PM
glide2meetu's Avatar
glide2meetu
Get the codes, that will help. Blow by is normal when you run it a little hard.
Old Aug 11, 2013 | 06:07 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
the light coming back on after start up for 30 sec says it has stored a code.
Old Aug 11, 2013 | 06:09 PM
Iceman24's Avatar
Iceman24
Pull the codes little Padawan: https://www.hdforums.com/forum/elect...tic-codes.html
Old Aug 11, 2013 | 11:07 PM
Ranch Rider
Stage II
Originally Posted by Iceman24
Not sure this procedure works for my 03 FLHRI...I just get the P01CLr through P10CLr codes..
panman4977
EVO
Jun 24, 2015 08:07 AM
Fugly
Aug 3, 2012 08:17 AM
AdrianVall
Sep 6, 2011 04:44 PM
Jordy806
Sep 9, 2008 08:07 AM
gatorwalt
Jul 24, 2008 10:26 AM
