What causes head shake
Is head shake caused by neck bearings, tire pressures, springs, dampeners?
I know I was exceeding the posted speed limit, but easily had lean angle for another 10 mph. Not sure that it would have settled down before leaving the pavement if it had another 10 mph though.
Whats the proper technique when head shake occurs? Maintian throttle (this is what I did) Roll off throttle, Roll on throttle, Straighten the bike and apply rear brake?
Yes I know, Slow Down.. but you can go ahead and tell me to anyhow if you must
Do I need softer springs, stiffer springs, more dampening, less dampening, more tire presssure, weaker right wrist?
Thanks for your thoughts
