Steering not centered - Pulls Right
Old Jun 12, 2012 | 12:53 PM
RoadLord's Avatar
RoadLord
Tell the ol' lady to lean left!
Old Jun 12, 2012 | 12:59 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
Bent forks, tweeked triple tree, broken folk spring... all can cause this.
If the rear drive pulley/wheel is not aligned correctly it will "push" the bike to the right or left depending on the belt/pulley alignment. Just something to check.
Old Jun 12, 2012 | 08:56 PM
hardskull's Avatar
hardskull
sorry for the confusion! What? everyone can't read my mind? LOL. OK, the bike is up on the lift. Using a bulldog lift with the support on the belly of the bike. I have always used it when cleaning and such. normal to have the tire go to center when lifted, now , no matter what, it turns to the right.. the only thing that has happened is the dealer picking it up and delivering it back to me for basic stuff, like the rear brake switch recall. I noticed the last time it was delivered that the bike appeared to be ratcheted down much tighter on the right side than the left. I dunno if this can do something to the forks and all. Thank you all for your advice, and again, sorry for the confusion. I blame it on the pain meds.
Old Jun 12, 2012 | 09:01 PM
hardskull's Avatar
hardskull
the dealer did pick it up to check this for me last week. assured me that they adjusted the pinch bolts and center nut to speck with the harley swing test. Just odd that with no wiring attached, no fairing inner or outer, no clutch or brake cable, and it pulls so bad to right. I told them I am getting ready to be able to ride, and will be putting it all back together and documented it. I will ask them to check the items that you all have suggested. Great ideas you all.. thanks again. Wish it was something simple !
HDCPL4PLAY
14
Aug 4, 2018 01:59 PM
peddler
Jun 26, 2014 06:30 AM
l17ajp
Wheels/Tires
Jan 12, 2009 02:30 PM
fmbeach
Feb 29, 2008 07:30 AM
jstoy215
Jan 14, 2008 09:59 PM
