Drilling out Baffles
Old Jun 12, 2012 | 11:57 AM
Bo Joe's Avatar
Bo Joe
Default Drilling out Baffles
For those that have drilled out their baffles, do I use a 1 1/2 or a 1 3/4 inch hole saw. Did a search on the threads and some said one and some said the other.
If I use the 1 3/4 it is a tight fit and it looks like have I have to drill out about 1 - 2" length of the baffle. Is that correct?
BTW, this is on a 2012 SG.
Thanks for help...
Old Jun 12, 2012 | 09:24 PM
keneds's Avatar
keneds
If I recall....It is 1 3/4" That will take out just enough of the weld that holds the baffle in place. Then just file it clean and then shoot it with some flat black spray paint and it's all good. And try to shop vac out some of the metal flakes. Worked well for me.
Old Jun 12, 2012 | 09:34 PM
TUCCI's Avatar
TUCCI
Yup I played with my stock pipes awhile back and thats exactly what I did. You still have the cat in the header correct? I askt because if you dont, I dont think your going to like the sound. If you do, it should sound tamer.
Old Jun 12, 2012 | 10:26 PM
TCMAN's Avatar
TCMAN
Mine actually sounded pretty good with the baffle drilled and the "cat" removed from the headpipe.
RubberToe
Exhaust System Topics
Jul 17, 2015 11:58 AM
SoCalSoftailSlim
Dec 17, 2012 05:58 PM
volks-man
Oct 19, 2011 08:56 PM
bklanecky
Jul 2, 2009 09:45 AM
20FXST06
Sep 20, 2007 09:08 PM
