Critical fasteners
Old Jun 12, 2012 | 08:30 PM
aviaator's Avatar
aviaator
Default Critical fasteners
Ok I did a search and didn't find this specific answer:
All of the service checklists reference checking "critical fasteners." Anybody have a list of these "critical" fasteners?
Old Jun 12, 2012 | 08:35 PM
dawg's Avatar
dawg
Section 1.22, page 1-51 under Maintenance in your 2011 touring manual
Old Jun 12, 2012 | 08:37 PM
TUCCI's Avatar
TUCCI
I don't have an exact list, however I have always considered critical fasteners the bolts that are all over the engine that if allowed to come loose can cause leaks and all kinds of unhappiness. I generally get a good idea of the torque spec's and work my way around the bike and if I find one that's kinda loose, I will torque them.
Old Jun 12, 2012 | 08:42 PM
aviaator's Avatar
aviaator
That would be very helpful if I had a manual.
Old Jun 12, 2012 | 08:45 PM
SJ12DS's Avatar
SJ12DS
As Dawg stated above it is in your service manual and list them specifically with torque specs. Mine is an 05 and it is in the general maintenance section which is the first section of the manual like page 1-56 or so. Most of the critical fasteners by the manual deal with the brakes, axles, controls and steering. Good luck.
Old Jun 12, 2012 | 08:47 PM
dawg's Avatar
dawg
Tisk, tisk, that should be on your list as a necessity. See attached.
Attached Thumbnails Critical fasteners-critical-fasteners.jpg   Critical fasteners-critical-fasteners2.jpg
Old Jun 12, 2012 | 08:54 PM
aviaator's Avatar
aviaator
Perfect. Exactly the info I was searching for. Thank you. And now it is here on the forum for everyone else to use and learn from.
Old Jun 12, 2012 | 09:52 PM
mkguitar's Avatar
mkguitar
the tranny end cover bolt torque has been changed to 25 ft lbs. this can be a source of leaks/seeps. esp. the 2 bolts which mount the exhaust.
mike
Old Jun 12, 2012 | 09:59 PM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
Anything that can kill you if it comes loose is a "critical" fastener
Old Jun 13, 2012 | 11:46 AM
aviaator's Avatar
aviaator
Thanks mkguitar, I had read that before and have it marked in my notes, but it's important enough to bear repeating.
rhsmd1
2014-2024 Touring Models
24
Jan 23, 2025 11:49 AM
745forhd
Apr 8, 2017 09:32 AM
Axxman
Sep 14, 2013 09:18 AM
flhxmc
Jan 22, 2013 08:41 PM
indyjeff
Sep 30, 2007 09:52 PM
