SG headlight upgrade
Old Jun 15, 2012 | 09:00 AM
  #31
iclick's Avatar
iclick
Originally Posted by btsom
Back to the cheap improvements: Just stumbled onto the Eiko 49111 100 watt/80 watt H4 bulb. What attracts me to it is the anticipated life rating. 800 hours for the low beam, 150 hours for the high beam. The price is competitive with the Silverstar. My shade tree reasoing on this is that the headlight circuit is protected by a 15 amp fuse meaning that the wire must have a higher rating or the wire would fail before the fuse. Using standard P=IE math says that a headlight up to 108 watts using a voltage of 13.8 is safe. The passing lights are on a different circuit. 896 bulbs are 37.5 watts and provide a bit more light at about the same price as the 27 watt standard bulbs. Compatible 50 watt bulbs are available but I haven't found any with the little black shield on the bulb tip. Without that, the filaments make a lot glare for on-coming drivers.
I have tried a NAPA 100/80 watt H4 bulb and it worked fine but died in a few weeks, hence the search for something else. The Eiko bulb is available on special order from Oreilly's and also over the net. I think next time I will try one of the net sources. Just Google the bulb number and several suppliers show up. Several of the net sources provide anticipated hours of bulb life, one thing to consider for making value judgements.
The Hella 80/100w bulbs also have a low average life rating (100 hours), but in 14 years of using them I've replaced one that I can recall--maybe two. The one on my SG now has been on the bike since new (5˝ years and 55k miles) and was on my old RK for another few years before that. I've been using a modulator since 2004 and that should extend bulb life since they pulsate at 20-100% 4x/sec. (daytime only), thus making the bulb run cooler--but even before that these bulbs seemed to be very durable.
Old Jun 26, 2012 | 06:50 PM
  #32
jeeping1974's Avatar
jeeping1974
I recieved the 55w hi/low kit from DDM tuning. With no basic instructions it took a little longer than I would have thought for install. Loosing the positive battery terminal screw and trying to figure out how to run the power wire from the batter to the fairing without fully removing the gas tank didn't really help though.
But in the end it works and it is bright! I'll be taking the bike to work tomorrow morning around 430am so I'll see just how bright it really is.
Old Jun 26, 2012 | 06:58 PM
  #33
CHILLLS's Avatar
CHILLLS
yes you are are correct they never come with instructions but they are really just plug & play.
to remove the tank on the 09-11 street glides is just 4 bolts, quick disconnect fuel coupler & then the harness underneath (easier when tank is empty)
you should be amazed over the light output tomorrow.
Old Jun 27, 2012 | 01:19 AM
  #34
jpglide's Avatar
jpglide
+1 I did this upgrade on my SG - huge improvement for not a lot of dough! Might still upgrade to LED's if prices come down enough, but no hurry cause this iClick solution is awesome bang for the buck.
Originally Posted by iclick
I'm using the Hella E-code headlights with Hella 80/100W bulbs. Great upgrade for little money. No problems running the higher-wattage bulbs in my old RK and current SG for 14 years.
Old Jun 27, 2012 | 04:44 AM
  #35
jeeping1974
My SG is an 06 and the fuel hoses have a crimp style clamp (not sure why they didn't use a reuseable style). I probably could have just replaced them with some regular hose clamps but I didn't.
The kit I recieved looks like it was wired for two headlights. I ended up just zip tieing everything together and out of the way. But yeah for $64 shipped, you can't go wrong with this kit. Plus the bulb is suppose to be good for >3000 hours and they are pretty cheap to replace.
With the rain this morning, I was unable to ride into work. Hoping tomorrow will be nice.
Old Jun 27, 2012 | 05:05 AM
  #36
slammed05fatty's Avatar
slammed05fatty
i love my 35w 6000k hid in mine, and eveybody tells me they notice me alot easier even in the daytime
Old Jun 27, 2012 | 07:24 AM
  #37
CHILLLS's Avatar
CHILLLS
i think thats because its a crisper/whiter light output that is not so dim & blends into the surroundings.
love mine too & i will install these in every vehicle from now on.
Old Jun 27, 2012 | 08:15 AM
  #38
frog13's Avatar
frog13
Originally Posted by springer 03
I have the H.D. LED in black. It definitely makes street and highway signs jump out a lot further away. The $440 price tag which includes a 20% discount is expensive but it does look kewl and the performance is much better. I'm in so deep now that cost of stuff I like doesn't weigh in so much anymore.
+1 on all that!
Attached Thumbnails SG headlight upgrade-a-front-reduced.jpg   SG headlight upgrade-a-left-side-reduced.jpg
Old Jun 27, 2012 | 09:33 AM
  #39
risuperglidecustomman's Avatar
Both my Harley LED headlight & aux lights are arriving today!
Old Jun 27, 2012 | 09:51 AM
  #40
racklefratz's Avatar
racklefratz
HD offers a "black LED headlight" as an upgrade. Anyone running this and like it? Is there another light that is as good or better for cheaper?
For the record, HD offers their LED light in both clear and black, IIRC.
"As good or better for cheaper"? What you'll find with that question is lots of folks who've upgraded to lots of stuff, but few have done that and the HD LED light as well, so they have no basis for comparison. So, the question will remain unanswered, essentially.
Personally, when it comes to such critical safety-related items as headlights, I don't tend to go the bargain-basement route - the stakes are too high. I will say that since I installed my HD clear LED headlight, I notice a lot less cars pulling out from side streets into my right of way, and the thing is much brighter than the stock light. I consider it money well spent. I'd do it again.
