What year is your bike? If it's '07 and older you need to change the master cylinder from 11/16 stock to a 9/16 from a softail/dyna with single rotor.
I've been running a single front rotor for 5 years. Up until now I've had a Jaybrake 6 piston on an 11.5" HD 2 piece rotor with a 9/16. I'm running a 7/8" banjo fitting on the mc and a 3/8 banjoe fitting on the caliper. It works pretty good. I'm upgrading to a 13" rotor right now. Hoping for even better performance.
I will be selling my 6 piston Jaybrake once my new caliper comes in if your interested.
Arlen ness has a new setup where it runs two calipers on a single disc. don't know how it stops, but it looks kinda cool and is way different, something to think about
funny you should mention that
my dad has a set up for twin calipers on one disc and has had for yrs, but brand new and never fitted
hmmm might have a look at that and see if i can fit it on the RKC now you mention it
Why on earth would you reduce your bikes stopping power?!?! Cool has a place but, it's not on a big *** touring bike's stopping ability! Man, I'm all for someone twisting their own nipples and all, so don't take it the wrong way but, I gotta just ask, why!
well if i can get the same sort of stopping power out of a PM caliper ( as HD ones are crap anyway) then i might as well just go for that and have a full open side on one side of the wheel and show off the 21" better
i dont ride hard or fast so wouldnt make any difference really to stopping and my dads heritage softail springer stops just as quick as my RKC with one caliper and rotor
im thiking of taking one of the rotars/calipers off the RKC as ive just fitted a 21" front wheel and you cant see much of it
so is it a massive difference on breaking ?
also i have a set of PM calipers so could use one of those if need be for better breaking power
thanks
You get much better feel at the lever and better brake modulation with dual front rotors. Also less pressure is required at the lever with dual rotors. There is less pressure at the pad for a similar level of braking with dual rotors so much less risk of accidental wheel lock during hard braking and less risk of brake fade. If your bike is for show it is not going to matter but if you ride it I would leave it on. Bikes that only use a single rotor do it as a cost saving measure. You need dual rotors on a heavy bike.
