Navigation Interface
Old Jun 18, 2012 | 11:12 AM
Roger79111's Avatar
Roger79111
I guess this evening I'll pull the outer off and check all the connections out.
Old Jun 18, 2012 | 11:22 AM
Roger79111's Avatar
Roger79111
Just to make sure, there is no "activating" the nim? The head unit should pick it up automatically?
Old Jun 18, 2012 | 11:23 AM
Airborne350G's Avatar
Airborne350G
Yep, as long as all the pins are secure then it should see it.
Old Jun 18, 2012 | 11:41 AM
Roger79111's Avatar
Roger79111
I just hate being the first in a bunch to do something.
Old Jun 18, 2012 | 11:47 AM
vzts4q's Avatar
vzts4q
You are hardly the first, when these first came out there was a error in the instructions. I guess there is the possibility that you got a older unit. Do you have the part number you installed handy.
The current part number is 76000024A there should also be a date next to the part number. Mine was 3/19/2012 and it worked correctly when I installed it last month.
Old Jun 18, 2012 | 12:03 PM
Roger79111's Avatar
Roger79111
Ha-ha, well the first in my group.
Mine was the A part number. The date is late 2011.
Old Jun 18, 2012 | 12:32 PM
JY107@SBCGLOBAL.NET's Avatar
JY107@SBCGLOBAL.NET
Stage II
When I installed mine last year I read there was some incorrect instructions, contact the dealer and verify your wiring instructions. I believe it was 2 pins on the radio input.
Old Jun 18, 2012 | 01:49 PM
White Ice's Avatar
White Ice
It is a Road Tech 660 and not the regular Garmin 660, correct?
Old Jun 18, 2012 | 03:38 PM
Roger79111's Avatar
Roger79111
Yes it is a Road Tech
Old Jun 18, 2012 | 04:17 PM
racechaser's Avatar
racechaser
I installed the 660 on my Limited and couldnt get sound through the speakers. Check the 35 or 36 pin plug and be definately sure that the additional pins are seated, I believe I added about five of them. Make sure your speaker rocker switch is in the lighted position, those pins may look seated but they must be in, they actually click if you can hear it, good luck,,,...o~' o
