Vibration, tough to pinpoint
I am looking for ideas on how I might better describe problem or perhaps something I might try to make it more obvious. All thoughts welcome.
24-2500 ( all gears, all speeds)differs from yours. Started right after a rear tire change and
The rear drive belt was left way too tight. I took it in for this issue and they ended up
Replacing the inner main bearing in the tranny. Problem is, the issues I had complained
About originally are still there. ESP won't pay for diagnostic so since
I got dissed by the dealer, I called HD Canada and explained my problem to them.
RPM specific vibrations can be many things from engine mounts to engine crank run out.
To bad bearings in the tranny.
