Does weight play a role in acceleration? Who wins??
In reality a 50% decrease in weight roughly equals a 100% increase in HP. A 25% decrease in weight roughly equals a 33% increase in HP.
Or, to put it another way, the inverse of your final weight over your starting weight is the ratio of final HP equivalence to starting HP.
Example:
Dropping from 500 lbs. to 400 lbs. puts you at 400/500ths of your starting weight, which is the equivalent of having 500/400ths of your starting HP. So if your starting HP was 60, you're now equivalent to 500/400ths of that, or 5/4ths, or +25%, or 75 HP equivalent.
So if you want to look at bang for the buck, decide which is better: dropping from 500 to 400 lbs., or increasing from 60 to 75 HP.
In this specific case every HP is equal to 6.7 lbs when taken in total. But if you do the same with a 1,000 lb. bike and bring it down to 900 lbs., that's the equivalent of increasing its 60 HP motor to only 6.7 HP, to 66.7, or having each HP be equal to 15 lbs. when taken in total.
All of this, of course, neglects the rider weight, which must also be factored in, as well as how much of the loss of mass comes from sprung versus unsprung locations.
