Does weight play a role in acceleration? Who wins??
Old Jun 21, 2012 | 10:38 AM
  #31
grbrown's Avatar
grbrown
Thumbs up
Originally Posted by icepick
Hey guys, many years ago I was curious about the same thing and used real world data accumulated by car and driver magazine to graph lbs/torque vs 1/4 mile times. it was very linear using data from a couple of hundred makes and models. sure there are some minor variables between riders and tires, but basically it is all about lbs/torque. after 1/4 mile, as speed increases, then HP kicks in as the mass is already accelerated a lot, rpms are up and wind resistance becomes a huge factor...which has everything to do with the color of the bike....ha
Hit the nail right on the head, well done.
Old Jun 21, 2012 | 10:45 AM
  #32
cruzmisl's Avatar
cruzmisl
Originally Posted by 0ldhippie
Using this 1/4 mile ET calculator http://robrobinette.com/et.htm My rodded 50hp 300lb drz400 will do the same 12.5 1/4 as my 700lb 90hp 103 EG. I added my 200# to each and it is for cars but the math is the same if maybe not correct for bikes? My old 400# 130hp ninja comes out at 9.7 So I've really stepped down in my old age. Pisses me off too! I will also like to call BS on a 400# fxr???
Using that cool calculator and using 810lbs, 927lbs for the RK and CVO respectively and the same HP (used 100 and 115) the difference was a half a second or so in the 1/4 mile for the RK. Using the stock figures of 80hp (CVO) and 65hp (RK) the difference is 3/10ths quicker in the 1/4 than the RK.
Pretty cool.
Old Jun 21, 2012 | 10:48 AM
  #33
blue flht's Avatar
blue flht
So if I get this right, if I quit the BEER and BBQ my times will pick up?
Old Jun 21, 2012 | 11:37 AM
  #34
grbrown's Avatar
grbrown
Wink
Blue FLHS here. Undeniably!
As for that calculator, it is frankly misleading to use it here on this subject. To start with it is torque not power that gets you off the line, as already stated. In addition, a high torque figure at low rpm will give better results on one of our touring bikes compared with the same number at the top of the rev range.
If you have looked at dyno curves in HDF recently, there are some excellent ones with very high torque in the low/mid rev range, with a lower HP number than TQ. Despite that they will give the best butt-gauge acceleration.
Old Jun 21, 2012 | 11:55 AM
  #35
mgmmgm's Avatar
mgmmgm
Ah Ha!
My friend is 6-2 275#- not really fat, but just a big strong guy.
He has a 2008 CVO RK, Vance and Hines true duals and V&H slash cut mufflers.Ventilator A/C with K&N.
I am 6-0 and 170 2011 RKC, SE 255 cams, V&H power duals and V&H monster rounds sane A/C unit with K&N.
We rode 1500 miles together last August, to California, he could always pull away from me.
Old Jun 21, 2012 | 12:05 PM
  #36
cruzmisl's Avatar
cruzmisl
That's interesting. Does he pull by a lot? Based on your numbers and mods I'd bet it would have been close but I've been wrong before.
Old Jun 21, 2012 | 12:31 PM
  #37
dyna07custom's Avatar
dyna07custom
Originally Posted by ynots
horsepower to weight ratio is no secret
A 750lb bike with 90hp would perform the same as 625lb bike with 75hp
They both have 1hp for every 8.33lbs
The 750lb bike requires 16.667% more HP
That is the correct answer in theory but rider weight, height, ambient temp, wind speed,aerodynamics (Fairings), shift points, race duration will all make contributions to the outcome
Old Jun 21, 2012 | 12:41 PM
  #38
Deuuuce's Avatar
Deuuuce
Don't forget gearing and torque, including under the curve.
For instance, tuned 6.1 SRT-8s could trap 113/114mph and run mid/high 12s.
However heavier, stock 6.4 SRT-8s, same horsepower, more torque all over the powerband trap the same mph, but can run low 12s.
Originally Posted by Expat1
we can only change the friction coefficient between the driving wheel and pavement assuming we have enough power in reserve. Slicks, all weather and rain tires were developed for adapting to the terrain. So if you have the proper tires on a heavy CVO and perhaps the same model of tires on a lighter RK the weight ratio doesn't really apply because the deformation of both rear tires will be different during acceleration and the grip of the rubber material onto the pavement will also differ.
Road rally conditions "in my younger days" showed there was a gain of 5 seconds per mile between each type of tire of a same manufacturer.
That is totally false when comparing street tires in a straight line and any difference isn't even measurable unless there is obviously slippage.
Originally Posted by RK Joy
It does take extra HP to accelerate extra mass. But rolling resistance and other factors come into play. At the end of the day, though, I would not be concerned about drag-race performance on my tour bike.
Aero and gearing will come into play LONG before rolling resistance.
Personally, if my SG runs 12s I'd be happy.
Old Jun 21, 2012 | 01:17 PM
  #39
Gearhead3's Avatar
Gearhead3
I've read the whole post and didn't see where anybody had mentioned rotating mass. If you put lighter wheels and tires on a vehicle, there's less rotating mass to accelerate. As far as automobiles go, for every 1 pound of rotating mass you add/remove from the wheel/tire assembly is equal to adding or removing 7 pounds from the total weight of the vehicle. ie: If you put a new lighter wheel and tire assembly on the vehicle that weighs 10 pounds less, it's like removing 70 pounds of static mass (weight) from the vehicle. It could add up quickly, too. 10 lbs. per wheel (which is very easy to do) x 4 wheels = 40 lbs. of rotating mass, 40 lbs. of rotating mass x 7 lbs. of static mass is the equivalent of removing 280 lbs. from the vehicle. This also applies to rotating mass in the engine (lighter crank, rods, pistons, etc.) Even items such as the driveshaft weight (again it is rotating mass) can be reduced to help out. Lightweight braking components, lug nuts (titanium) lighter harmonic balancers, the list goes on and on. Bear in mind, on some items where the mass is located closer to the center of rotation (lug nuts, for example) you won't see the same results as if the weight were located more towards the outer diameter of the rotating assembly. This could (obviously) be applied to your bike, but on a smaller scale. Just bear in mind, every little bit helps.
Old Jun 21, 2012 | 01:28 PM
  #40
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Have you heard about this tire manufacturer?
http://www.michelin-power.com/
MICHELIN Power Cup A,
MICHELIN Power Cup B,
MICHELIN Power Cup C,
MICHELIN Power Slick,
MICHELIN Power Rain.
They've assessed this topic before.
