2002 Road King
Old Jun 25, 2012 | 01:08 AM
Bartman1959's Avatar
Bartman1959
4th Gear
Question 2002 Road King
My 2002 fuel injected Road King is running like crap as soon as it warms up. It starts running on one cylinder, and that one is missing pretty bad. The codes that come up are PPU, and 82883...
Any ideas why my problem(s) my lie?
The bike only has 23,000 miles on the clock.
Thanks
Bartman1959
Old Jun 25, 2012 | 01:13 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
My neighbor also has a 2002 RK Classic and he had a similar problem.
The tech who repaired it said it was a chaffed fuel injection wire and this is casued by the way the wiring harness was routed and tied to the frame.
Hope this helps.
Old Jun 25, 2012 | 01:23 AM
Bartman1959
4th Gear
Thanks, I'll check wiring when I get home from work in the morning...
Old Jun 25, 2012 | 01:26 AM
king04's Avatar
king04
3rd Gear
Also check the fuel line that's in the tank. It rubs and can get pinholes in it. Mine was running like crap and turned out to be the intake gaskets. Spent 2.5 hours at my local indy before diagnosis and then 1.5 hours to swap em out. Got out for $100 total!
Old Jun 25, 2012 | 01:41 AM
Bartman1959
4th Gear
I'll both of those areas too...
Thanks
Old Jun 25, 2012 | 05:18 PM
mrmud4x4's Avatar
mrmud4x4
Engine temp sensor? (right behind the horn)
CPS - crank position sensor
Plug wires.
If it is your fuel lines...the problem will occur as your fuel in the tank gets low.
Might want to change your fuel filter.
Also....vibration can cause the fuel injector connections to come off or break internally.
Those codes do not look familiar. If you know someone with a Power Vision....they can plug it into your bike and get the codes pretty easily, present and history.
Otherwise, search how to get codes for the 88TC your year....it's on the forum.
hope this helps...
Post what you find out...thanks.
Old Jun 25, 2012 | 05:33 PM
mrmud4x4's Avatar
mrmud4x4
here.....
https://www.hdforums.com/forum/softa...l?ref=esp-link
lizard1
Nov 25, 2017 04:28 AM
GFanaticLSU
General Topics/Tech Tips
May 13, 2014 07:11 PM
captaincaveman
Apr 20, 2010 12:40 PM
lloyd67
Aug 29, 2008 05:27 PM
harleyking38
Jan 20, 2006 08:24 AM
