CB reception distance
Old Jun 29, 2012 | 09:48 PM
nivensid's Avatar
nivensid
Default CB reception distance
I have had my Limited for a year now and have never used the CB. I have read the average reception and transmission is 1/4 mile.
Anyone getting better distance? I will be riding the bike and the wife will bew in a car with her CB due to her surgery. I hope a 1/4 mile range is not going to be the best range. What can I expect realistically?
Old Jun 29, 2012 | 10:07 PM
SpiderPig's Avatar
SpiderPig
Yup 1/4 is about right.
Old Jun 29, 2012 | 10:12 PM
Cowboy Rob's Avatar
Cowboy Rob
Big Kahuna HDF Member
Depending on terrain you will be lucky to get that.
Old Jun 29, 2012 | 10:33 PM
SportyPig's Avatar
SportyPig
Wish I could get a 1/4 mile. I live 400 ft. off a major interstate. If I turn on the CB in the driveway, I don't receive anything.
Old Jun 30, 2012 | 07:10 AM
K Melancon's Avatar
K Melancon
Check to make sure the CB antenna is on the right side of trunk. Get a radio shop to tune the SWR from the connector under the trunk liner.
Old Jun 30, 2012 | 07:22 AM
RK Joy's Avatar
RK Joy
I am stunned to hear the range being so short, having been into CB in its hay day. I know a motorcycle does not have the best reflective surfaces (ground plane) but if the radios run at the 5 watt maximum with decent antennas, I still would expect miles, not small fractions of miles. Possibly FRS or GMRS would provide better performance, with a much more compact antenna system.
Old Jun 30, 2012 | 01:02 PM
Sporty302's Avatar
Sporty302
+1 on checking to make sure the CB antenna is on the correct side of the tour pack. On my 2011 FLHTCU I bent the left side antenna. Checked the parts manual and saw that I needed a replacement AM/FM antenna so I got one from my H-D dealer. Went to put it on and, when examining the original bent one I saw CB embossed near the base. So mine were incorrect when I bought it. I suspect a mistake was made when the new bike prep work was done by the dealer. OEM AM/FM and CB antennas look identical but each is embossed near the base with either AM/FM or CB.
Old Jun 30, 2012 | 02:12 PM
jimharvey1's Avatar
jimharvey1
Yeah, ź-˝ mile is about it. The HK CB Radio isn't like your standard automotive or big-truck CB. I really don't believe it cranks out the 4-watt max. The ground plane of a motorcycle really sucks. I've chatted with big trucks on the highway but was only 3 or 4 cars away at the time. The squelch on the HK radio seems to be different as well. You're right about GRMS radios having better range.
Old Jun 30, 2012 | 02:29 PM
JC Turbo's Avatar
JC Turbo
So which side should the cb antenna be on?
Old Jun 30, 2012 | 03:41 PM
Sporty302's Avatar
Sporty302
JC Turbo, CB on the right side, AM/FM on the left side for my 2011 FLHTCU.
