Battery not chargeing
Old Jul 2, 2012 | 09:52 AM
fabricater's Avatar
fabricater
Default Battery not chargeing
2005 ultra classic not charging.when it is running it drops to 11 volts.when turn off driving lights the battery light goes out,so it must be charging some but not enough.The cables have been checked to make sure they are tight.any suggestion?
Old Jul 2, 2012 | 10:07 AM
mrfikser's Avatar
mrfikser
first off take the battery out and have it tested at the store...after that you should check the charging system it could be either the regulator of the stator...does the voltage go up when you rev the motor???
Old Jul 2, 2012 | 10:11 AM
fabricater's Avatar
fabricater
No the voltage does not go up when the RPM is increased
Old Jul 2, 2012 | 10:16 AM
fabricater's Avatar
fabricater
How do I check the regulator and the stator to figure out if the stator is working or not
Stromhammar
Dec 21, 2022 07:57 PM
Junior in NE
Aug 18, 2014 06:44 PM
ryanlberg
Apr 11, 2012 04:10 PM
hucks 08
May 26, 2010 07:23 PM
geedub
Aug 28, 2008 08:01 PM
