Check engine and Battery light on, need input
Old Aug 17, 2014 | 06:50 PM
Junior in NE's Avatar
Junior in NE
Default Check engine and Battery light on, need input
Both lights came on while I was running around town, along with the volt guage being around 10. There was a DTC that was for low battery voltage. So I went home, pulled the battery and had it tested and it was good. I checked the wiring connections at the voltage regulator and battery along with the grounds and everything seem to be fine. I then started the bike up again and checked the battery with a multimeter and it was around 14.5. The trouble lights were not on at this time. Toook the bike out for a little spin an everything seemed normal, volt guage was between 14 and 15. It's a 2012 flhx. What should I be looking at or testing next?
Old Aug 17, 2014 | 07:03 PM
dawg's Avatar
dawg
Voltage Regulator
Old Aug 17, 2014 | 07:05 PM
dawg's Avatar
dawg
M1325 service bulletin....voltage regulator campaign for 2012's
Old Aug 17, 2014 | 07:27 PM
HDJIM1158's Avatar
HDJIM1158
I just had the same problem, Voltage Regulator replaced.... All is well 2012 Ultra Classic.
Be Safe JIM
Old Aug 18, 2014 | 05:12 PM
Junior in NE
Thanks for the input. I read through the bulletin and the time frame for them replacing the regulators for free expired 2 months ago. Just my luck. Not sure how they can regulate a time frame to fix a known problem, so I guess I'll see what the dealer says.
Old Aug 18, 2014 | 06:44 PM
williamfrog's Avatar
williamfrog
If dealer says no call Harley they replaced a fender out of warranty for me
Napalm Dog
Aug 26, 2014 05:11 PM
TooEasy
Dec 19, 2012 05:19 PM
fabricater
Jul 2, 2012 10:16 AM
ryanlberg
Apr 11, 2012 04:10 PM
jjmil03
Feb 20, 2012 07:38 PM
