White smoke
Old Jul 3, 2012 | 11:42 AM
Scaredofrain's Avatar
Scaredofrain
White smoke? I didn't know they were voting for a new Pope?
Old Jul 3, 2012 | 12:39 PM
mrfikser's Avatar
mrfikser
rear cylinder breather pipe issue... maybe a piece of crap got into the rear cyl. breather pipe..or it is pinched somewhere
Old Jul 3, 2012 | 12:53 PM
LynnSG's Avatar
LynnSG
Thumbs up
Originally Posted by mkguitar
1.) white smoke is burning oil
a.) on acceleration is worn piston rings
b.) on decel is worn valve guides
2.)black smoke is too much gas for the air- "too rich" a mixture
white smoke says you are burning oil and have a mechanical problem which the tuner cannot remedy.
It "may" have played a part in this problem but unlikely.
and as you already know this is in the rear cylinder ( left side smoke)
*** possible that the installer mis installed the new air cleaner blocking the banjo bolt passage from the heads or rear head to the breather, causing oil to collect under the valve cover and pushing past the seals
mike
right on man!
Old Jul 3, 2012 | 03:15 PM
hoofnhog's Avatar
hoofnhog
anything can happen.... you are talking about a motor from a company that allows 10 thousands of crank runout as "within standards"????????? Imagine what they allow for ring gap tolerances????
Old Jul 3, 2012 | 03:29 PM
beary's Avatar
beary
I know, I know but are you sure it didn't smoke before. Just saying that maybe the other issues pointed opened your eyes on the burning oil.
Beary
Old Jul 3, 2012 | 07:27 PM
NevadaNick's Avatar
NevadaNick
It's most likely pulling oil through from the ac. Something in the ac is wrong or installed wrong.
Drlsgt's Avatar
Drlsgt
6th Gear
Thanks all!!!!
I took off the screamin eagle breather and put back the 360 K&N filter Rinehart originally put on with the pipe change. My bitch is running great! No over heating, singing like a MF. Is it safe to assume for that screamin eagle breather (elbow) other mods have to take place? On the highway she would sing with the screamin, but in the city sucking wind blowing white smoke. Looks like I'll be posting a screamin eagle heavy breather on eBay, she's runnin to good.
pgarbac
General Topics/Tech Tips
Mar 1, 2017 11:40 AM
jdh1340
Jan 2, 2015 03:14 PM
Ragnar Danneskjöld
Dec 6, 2014 05:03 PM
MIKEKIM
Sep 24, 2013 12:54 PM
