Front Tire Removal
Old Jul 4, 2012 | 03:26 PM
Keithhu's Avatar
Keithhu
Originally Posted by Airborne350G
Just did this. Did not remove the wheel. Used long screw driver and hammer to bend back the tabs by reaching through the wheel. Used blue locktight when re-installing. Front mount was a pain, but did it with a wrench.
Unbending wasnt really a problem. Bending the new ones was. I used blue loctite, but was paranoid about it. A few weeks later I had it in to the dealer to swap wheels, I made damn sure they bent the rest of the tabs I couldnt reach when they had the tire off.
Old Jul 4, 2012 | 04:48 PM
1st 96 ultra's Avatar
1st 96 ultra
did my wifes Heitage , no need to pull the wheel , did one side at a time and just left the bolts loose till all was done
Old Jul 4, 2012 | 05:20 PM
SeniorChief56's Avatar
SeniorChief56
Veteran: Coast Guard
just finished the "project". I did not remove the tire. Used a long wood chisel to bend back the tabs. Used some rags to support the fender instead of the block a wood as per the instructions. I used lock washers and blue loc-tite and did not bend back the tbs...will probably bend them back when it's time for a new tire.Took about an hour working time.
Old Jul 4, 2012 | 05:23 PM
Keithhu's Avatar
Keithhu
There were tabs I simply could not reach with this method - the tabs facing the back of the bike on the rear bolts. Not sure what your secret was but I was not able to get those bent.
Old Jul 4, 2012 | 06:26 PM
SeniorChief56
one side I was unable to get "unbent" but was able to get a 1/2" box wrench on....they came off real easy as they were not torqued that much
Old Jul 4, 2012 | 07:04 PM
drukanfu's Avatar
drukanfu
I threw the tabs out, replaced the regular nuts with fiber lock nuts.
Old Jul 4, 2012 | 07:12 PM
SeniorChief56
ahem,there are no nuts to replace
Old Jul 4, 2012 | 07:59 PM
drukanfu's Avatar
drukanfu
Opps ! .... it's been a while and my memory failed me,go figure. I threw the &^#$^ tabs out and put blue lok-tite on the bolts.
warren827
Wheels/Tires
May 6, 2015 10:38 PM
supercrewser
Jun 12, 2010 12:36 PM
big_e78
Mar 15, 2010 06:15 PM
07Eglider
Jul 27, 2008 07:34 PM
Scott58
Apr 23, 2007 12:21 AM
