Rework
Old Jul 7, 2012 | 12:14 AM
swamperca's Avatar
swamperca
Default Rework
When getting your bike back from having some major service items done, how much rework should you have to do to get things right. I've had to reroute my new Clutch cable which was installed with the new clutch, which broke my auxiliary switch. Had to pull out my rear axial and reverse it's direction as I have single muffler so I don't have to pull it when changing rear tires, it was right when I took it in but they removed the rear tire to put on a new oil pan. Now after driving the bike the primary cover is leaking, they had it off to replace the clutch. This shop is known for excellent quality work but I'm just not sure how much rework I should expect as I've always done most of my own work in the past, Just didn't have the special tools for some of these repairs.
Old Jul 7, 2012 | 12:25 AM
JCleary's Avatar
JCleary
I would expect none! Rework is the sign of a sloppy mechanic.
I'd take it back and make them fix it all properly.
Old Jul 7, 2012 | 12:28 AM
dbell66253's Avatar
dbell66253
You really shouldn't have to do anything, the items you mentioned are already too much. When you take your bike to the shop for a minor or major repair, it should be returned ready to ride. The shop I go to even takes the bike out and rides it a few miles to check for issues.
Old Jul 7, 2012 | 09:50 AM
Pelonz's Avatar
Pelonz
"This shop is known for excellent quality "
If the above is true, take it back and make them aware of your issues, they will want to know that the tech who worked on your bike is not up to their standards.
Old Jul 7, 2012 | 10:10 AM
fxdxrdr's Avatar
fxdxrdr
the only rework you should have to do is adjust your mirrors
Old Jul 7, 2012 | 10:42 AM
NAILIT RK's Avatar
NAILIT RK
I would not have fixed any of it, take it back and let them do ALL the rework....
81TourKing00
Shovelhead
11
Sep 12, 2013 04:53 PM
tmilti1
Apr 18, 2013 11:21 AM
osceana
Sep 23, 2012 04:26 PM
renotunes
Ironhead
Aug 9, 2012 11:22 PM
1flhtk4me
Jul 1, 2007 01:56 PM
