Just found a drywall screw in my rear tire. This is a new set of tires, less than 4000 miles on them. Is plugging the tire on the bike a safe option? Or is it new tire time?
It's probably OK to plug it but being the paranoid person I am, I would replace the tire,,, scary feeling when a tire blows, or a real bitch when you come out from work or a bar and find you had a slow leak,,,
I've been plugging mine for years. I plugged a rear tire with about 5K on it and then rode from NC to San Diego. Never
gave me a problem. Of course it's all a matter of choice, but the plugs DO work and it will keep a considerable amount of
money staying in your wallet!
Bike tires are diferent than car tires in that you only have 2 tires that support you. A blow out on a bike can be a bit more un safe for obvious reasons. I would replace the tire just for safety sake. I feel that my worthless life is worth more than the cost of the tire.
I have plugged tires with suscess, but I feel that it is a temporary fix. If you want to keep the tire, break it down and do a proper fix from the inside. Just an opinion.
I'm with Bill on this one! There's too much riding on a repaired tire to take a chance.
ORIGINAL: billnourse
The screw was deep in one of the grooves about 1" away from the left side of the rib in the meat of the tire.
I talked to my dad about it, (35 year wrench) and he put my fear of plugging the tire to rest. I used a 7" Camel brand plug and rubber cement. No bubbles with soapy water. I'll keep an eye on it, if it leaks it's getting replaced.
Dad says he went 2 seasons on a plugged rear tire, till it was worn out.
sheet rock screws.......gotta love em 2 in 2 weeks!
Yeah, the friggin screw I pulled out was no ordinary drywall screw. It was a 1 1/4" hardened #10 bugle head. It must have been in there for a while, the head was worn down to the bottom of the phillips drive.
What did you do to fix your tire?
I was at my local stealer yesterday, they had a sign on the window 20% off Dunlop tires. But its a 3 week wait for them to change a tire. Rediculous! I walked back through the service area and not 1 wrench was turning, 3 techs were just standing in a circle b/s ing. Do dealer techs work on flat rate or are they hourly?
_____________________________
96 FLHTC
Change it yourself as I doubt the ability of those clowns. Yes they stroke the clock if on salery and only do 1/2 the job if on commission lol
