The dreaded PINING on the 103!
Old Nov 16, 2012 | 07:07 AM
  #101
upstater's Avatar
upstater
Originally Posted by Fathertime500
Nice, so when I'm cruising at 70 mph in 6th gear at 2500 rpm on flat smooth road with no headwind and hear pinging just drop it down a gear. WOW! Glad your not dealing with this problem. Thanks buddy!
Sadly, this is a true story.
I have the exact same symptoms. Dealer called while I was there. I asked the dealer to request an ECM update that others have had done with good results. It required the dealer to send the ECM to Harley. They said I had the most recent update(B) and that was all they could do. Then came the suggestion to gear down and raise RPM's to 3k.
Old Nov 16, 2012 | 07:35 AM
  #102
mxz600's Avatar
mxz600
My dealer sent my ecm to Harley a few weeks ago. I got the bike back last week and asked the dealer what Harley did and the service manager said he did not know (duh). You would think they would at least inquire what was done to the ecm so they might be educated on this matter. I decided to call Harley myself and see if I could get answers. The guy that answered my call said all they did was retard the timing in a few areas and I should be all set. He also said that I could ride the bike all day long everyday with it pinging and that it would not harm the engine whatsoever. Not sure if I believe that!! Anyways I did the ride the bike about 200 miles and it did seem better but it also was only 65 degrees out. I guess the real proof in the pudding so to speak will be next year when it gets out outside what will it do. For now I am satisfied that at least they are trying to fix it. Just wish my dealer was a little more on top of the situation.
Old Nov 16, 2012 | 10:06 AM
  #103
Bingee's Avatar
Bingee
I believe the MOCO is required by law to maintain EPA exhaust emission standards for any changes it makes to its bikes or instructs others to make. Violations mean big fines. However, if you obtain a SEPST, TTS, or other tuning device and learn how to use it you can eliminate the pinging while maintaining or even increasing your engine power.
Old Nov 16, 2012 | 10:10 AM
  #104
TUCCI's Avatar
TUCCI
Im not satisfied with a vague answer like that and although I had to put a PCV on to do it, I can tell you exactly where and how much timing was adjusted. My map a few pages back shows where and how much. Very alarming statement made by them being able to run it pinging all day....wonder if they had 20k wrapped up in a bike if that would fly with them......idiots.
Old Nov 16, 2012 | 05:34 PM
  #105
lh4x4's Avatar
lh4x4
With over 6K on my 12 RGC and no pinging, I felt left out. So yesterday when leaving town I was at 45 mpg. I put it in 5th and went WOT. Sure enough I head that sucker ping like mad. I feel better now.
Old Nov 16, 2012 | 08:49 PM
  #106
Guzz's Avatar
Guzz
Originally Posted by rufasim
It sounds like all the pinging is coming from bikes that have done atleast a stage 1. Has anyone heard of a pinging problem with a stock set up. I was thinking of doing a stage one but may just keep it stock and replace only the mufflers with monster ovals.
Mine didn't ping until the dealer put in a SE255 and dyno'ed it (at 5k maintenance). I also had them install a set of pipes I got that had CAT gutted. It pings in 5 and 6th, and sometimes even 4th. Happens when I roll it on on a slight (and I mean SLIGHT grade).
I am running the SEPST and bought the cables and software. Plan to study it a bit then try it myself, backing off timing in the affected ranges. I do not know enough yet about the SEPST. Not sure it will show where it is pinging after a data record, and if the smart tune will make suggestions. If anyone knows more about this, would be greatly interested in hearing more.
Also, for those who have retarded the timing successfully, am interested in hearing how your performance was affected.
Old Nov 16, 2012 | 09:04 PM
  #107
Guzz's Avatar
Guzz
Originally Posted by traveler
Adding a touch of fuel may be better.....pulling timing really kills power, and the engine will actually run cooler. These bikes are VERY lean from the factory to meet EPA requirements.
I think alot of the noise comes from.....if you are used to riding water cooled bikes, the water jackets on the motor insulate alot of the valvetrain noise. With the aircooled engine, those noises are now present. When I got my first Harley in 2005, I found it a bit unnerving until I was told by a good Harley mechanic that's the way they are (with a big grin ). Just food for thought.
~Joe
You anticipated my next question... will adding fuel produce the same results as retarding the timing? And can it be done on using the SEPST software? I know they run leaner than hell with factory settings.
Old Nov 16, 2012 | 09:06 PM
  #108
Guzz's Avatar
Guzz
Originally Posted by flapjack
Don't want to sound like an idiot but have been told no such thing as a dumb question. Had a 103 build done on my 07 ultra, already had 255 cams and tru duals. When 103 was done had SEPRT put on as well, all work done by dealer and most covered under warranty. When first picked up had never been so quiet. After 400 miles or so started getting what I thought was lifter noise. Would this be the pinging were talking about? Will having it put on dyno and tuned help?
To me, the pinging sounds sounds like BB's rattling around in your pipes. It's annoying, like fingernails on a blackboard. It's not loud, it's tinny sounding.
Old Nov 16, 2012 | 11:16 PM
  #109
Bingee's Avatar
Bingee
I use the SEPST and have eliminated all detonation. I have a 2009 with a 103 stage II. The SE 255 cam works just fine. I never touched the timing. I first made a half dozen 45min smart tune runs to get my VE tables in line. That reduced the detonation by two thirds. Then I used the Closed Loop Bias table to richen the fuel (AFR of 14.24 or Lambda of around .970) in the RPM/MAP range where the pinging would occur. It took a little trial and errror. But, no more pinging.
Fair warning. Read up on this forum on how to use the SEPST before you make any attempt to tune. The SE documentation for the SEPST is NOT user friendly. But there are several forum members who know this stuff really well. You'll find their posts in the forum for the SEPST. Check 'em out.
Old Nov 17, 2012 | 07:11 AM
  #110
omaho5's Avatar
omaho5
You do not want the engine to have any pinging as it does TERRIBLE things,
As in destroying the thing.
JeffJA
Mar 30, 2018 02:11 PM
bigskyroadglide
Mar 21, 2014 08:43 PM
mhud
Sep 23, 2013 01:48 PM
keno
Apr 5, 2013 11:40 AM
masterblaster
Jan 22, 2010 07:20 AM
