Ideas
Old Jul 12, 2012 | 09:47 AM
Mingo 13's Avatar
Mingo 13
Nope just trying to figure out why its a 2500 difference in price. I think I will go with the 05 if its is good as it looks in the pictures
Old Jul 12, 2012 | 10:56 AM
mikebaby's Avatar
mikebaby
Don't pay a premium for the anniversary model. H-D milked that for all they could and the model year ended up longer than 12 mos.
mikebaby
Old Jul 12, 2012 | 01:22 PM
nvsteve's Avatar
nvsteve
There was an issue with early 05 valve seals. A buddy has an 05 and it didn't show up until about 15K. Find out if they have been replaced or if the bike was built after the date given on the Service Bulletin.
I'd go for the 05 if the issue is resolved.
Old Jul 12, 2012 | 01:28 PM
Mingo 13's Avatar
Mingo 13
Not sure but the 05 has 18,000 mi on it so Im not sure if he has had a problem and where can I find the Service Bulletin?
Old Jul 12, 2012 | 02:42 PM
nvsteve's Avatar
nvsteve
Not sure but someone here should be able to help you. It has the build dates that were affected. The build date is on the frame of the bike.
Old Jul 12, 2012 | 03:04 PM
rochkes's Avatar
rochkes
Even if the 05 is a date with the affected valve seals and they haven't been replaced, I'd still go with that one anyway. Valve seals are a big deal. This bike is still newer and cheaper.
Dennis
Old Jul 12, 2012 | 04:33 PM
Fathead2003's Avatar
Fathead2003
I have an 03 and I would go with the 05. My 03 has been solid but there were several changes I am sure from 03 to 05. The commom maintenance items on my 03 have been spongy front brake, muffler rubber mount replacements, and most recently the rear rocker box gasket replacement. All easily fixed. Inquire if the cam tensioners were replaced on either bike. That is a common problem for both . I went with the SE upgrade kit before they failed which could take out your engine. There may be specific problems with the 05 that you may want to look into. Either way these bikes run cooler than the newer ones which is a good thing. Good luck.
Old Jul 12, 2012 | 04:35 PM
Mark98012's Avatar
Mark98012
Color and mileage is the only difference.
Old Jul 12, 2012 | 04:40 PM
Iceman24's Avatar
Iceman24
If the 05 is truly a PE bike...hands down the better choice for added options that are above-n-beyond the std bike.
keith1073
Audio Systems
Apr 23, 2014 08:44 PM
aces25
Nov 18, 2011 12:27 PM
pfd161
Apr 17, 2007 12:45 PM
MACK
Motorcycles For Sale
Jan 4, 2007 11:47 AM
Anthony8858
Aug 29, 2006 09:04 PM
