Rim width is where the tyre sits, so inside. I am in the process of squeezing in a 4.5" Deuce wheel, with a 160/70 tyre. It is the tyre width that is giving me a clearance problem, rather than rim width! Tyre measures 167mm wide fitted, just over 6.5", which in a 7" fender is very cosy! I think I've cracked it, but it isn't a simple bolt-in.
if you replace the belt and pulley with an 07 +wider fender or cover fender .5.5 rim and 180 tire will fit
So, you're saying the '09 up tire and rim (5.5" rim 180mm tire) WILL fit within the '07 - '08 fender and fender struts with no problems? I ask this because I found a thread on here where someone trimmed up an '09 fender to make this combo work on an '07 or '08 FLHX, but I can't tell if there were any other modifications to make this work. Modifications like belt guard removal, hub spacing or pulley spacing.
Using aftermarket wheels with custom hub machining will allow a 180mm tire to be fitted within the frame & stock swingarm. The stock fender can be fitted also, but would require some tweaking.
I opted for using the '09 up OEM tire and rim (5.5" rim, 180mm tire) on my '07 FLHP. The stock swingarm was widened to accept the '09 up wheel/tire/axle assembly with the help of custom spacers. An '09 up fender was sliced & diced to fit properly and provide the protection intended. I was able to run the stock beltguard. Very inexpensive and easy winter downtime mod. Just another option. Heres the link:
