Glowing red hot
Old Jul 14, 2012 | 06:26 PM
TwoBlue02's Avatar
TwoBlue02
Default Glowing red hot
I am trying to chase down a chirp on my 02 Ultra (no success yet) so I have going around the bike, revving the motor etc. I noticed that the area of the exhaust right after it leaves the rear jug is bright glowing red.
Not having owned a Harley before, and never really looking for something like this on my other bikes -is this normal? If not --- then what?
Old Jul 14, 2012 | 06:45 PM
Deucedog's Avatar
Deucedog
Among many possible sources for the chirp may be an exhaust leak at the flange on the head. Where the pipe bolts to the head. The fact that the pipe is glowing red would lead me to check the fuel mixture on the rear cylinder. Either there is an exhaust leak or the carb is not setup correctly.
You didn't say if the bike has stock pipes, but if it has mufflers/baffles you might also check to make sure that they aren't plugged with some little critters nesting material or dislodged packing/insulation. This would cause a backup in the exhaust pressure in that pipe, resulting in an overheating pipe/s as well.
Old Jul 14, 2012 | 06:52 PM
gomiller2's Avatar
gomiller2
Sometimes you get a chirp from the rubber mounts just under the saddle bags were they bolt try spraying them with wd40 very commen problem but the glowing pipe dont no not good.
Old Jul 14, 2012 | 06:55 PM
Sauceman's Avatar
Sauceman
Yes, glowing pipes usually result from lean conditions or timing that is too far advanced.
cheers
Old Jul 14, 2012 | 06:58 PM
Stiggy's Avatar
Stiggy
How long of a time were you walking around the bike revving it?
Old Jul 14, 2012 | 07:22 PM
TwoBlue02's Avatar
TwoBlue02
Thanks for the input guys. Here are a few more facts (there's always a few more!)
As far as I know the chirp and the red pipe are two separate issues. I noticed the pipe while looking for the chirp. I noticed the chirp for the first time today. I put a taller shield on for my ride today so maybe this has been going on for a bit and I did not hear it due to a smaller windshield and the radio. I have have the bike for 1500 miles and do not remember hearing this before. It sounds like it is coming from the front left of the bike but with wind noise who knows.
Bike if FI so carb settings are not an issue. As far as I know bike is stock and no remapping has ever been done.
By rubber mounts under bags I assume you mean the ones attaching the pipes? I jiggled the pipes around without hearing anything but some silicone spray is worth a try.
I let the bike run for a while. Occasionally revving to 3k and holding it there for less than a minute at a time This was not constant. I noticed the pipe only glowed after the bike was revved for a while but can not see how this would be any different that just riding.
Thanks for helping with all of this.
Old Jul 14, 2012 | 07:28 PM
Stiggy's Avatar
Stiggy
There's no cooling air running across the motor sitting in your driveway when you're revving it at 3,000 rpm " for a while." Don't do that.
Push dpwn on the tops of the saddlebags and see if the chirping stops.
Run some WD 40 on the outside (only the outer edge) of the drive belt to see if the chirping stops, ( assuming it only happens when moving.)
Old Jul 14, 2012 | 07:29 PM
tibadoe's Avatar
tibadoe
I would pull the plugs ant see if its running lean.
Old Jul 14, 2012 | 07:50 PM
hambone51's Avatar
hambone51
Chirp gone on my `02 RK after dealer sprayed rubber on exhaust brackets also. No help on glowing red exhaust pipe.
Old Jul 14, 2012 | 09:19 PM
TwoBlue02's Avatar
TwoBlue02
I have the bags off. Will spray some silicon on the exhaust mounts and some WD 40 on the outer edge of the belt.
I'll let you guys know if there is an improvement tomorrow. Makes sense on the pipes hot because of no air. If the cigarette lighter craps out at least I will know how to light one..............
