Cracked Y pipe
Old Jul 16, 2012 | 12:09 AM
fwb35's Avatar
fwb35
I just did the fulsac true dual kit, $198 shipped to my door, worked great and sounds great.
Old Jul 16, 2012 | 12:58 AM
txfxstrider's Avatar
txfxstrider
When mine cracked I thought I would have no problem finding a take-off at the dealer but no luck. While I was trying to decide between the Fulsac and the V&H Classic Duals I finally decided to make a significant change and went with a black Thunderheader 2-1. Looks badazz, sounds badazz, runs great.
Old Jul 16, 2012 | 04:02 AM
hardwork2's Avatar
hardwork2
If you bought the ESP it is covered. The Y pipe is comon for breaking after the front motor mount. like someone else said.
I Wonder when H-D came out with the Improved front motor mount?
We put the Fulsac on my 05. not bad for a couple hundred bucks
Old Jul 16, 2012 | 05:59 AM
ddm502001's Avatar
ddm502001
I had the new mount on my '03 for a year when my 'Y' pipe cracked and started popping in the exhaust, chose not to weld it and replaced the pipes as once tempered/work hardened by time and the heat/cool of running the bike they will embrittle, would have to go pretty extreme for weld and peen or stress relieve to keep from it cracking again, not worth the trouble.
Have relced my pipes with a Khrome Werks variant to the newer style of pipes, there are other options, Bassani, V&H and others for true duals or you can buy late model take off, replace the oil pan with a new style and install the current style pipes. I lost about 5 degrees of right turn lean for cornering with these.
Attached Thumbnails Cracked Y pipe-dsc02263.jpg   Cracked Y pipe-harley-new-exhaust-007.jpg   Cracked Y pipe-harley-new-exhaust-008.jpg
Old Jul 17, 2012 | 09:13 PM
14longshot's Avatar
14longshot
The Fullsac true dual exhaust is on it's way hope it's here by friday.
$189.00 hopefully to MY door!!!
Old Jul 17, 2012 | 09:26 PM
Bill03E's Avatar
Bill03E
I have often thought of welding one with stainless steel rod, so the weld would not crack as easy, but I am not sure about it as of yet.
Old Jul 17, 2012 | 09:27 PM
checkers's Avatar
checkers
Originally Posted by 14longshot
The Y pipe on my 08 ultra cracked. What are people doing to fix this are they putting oem parts back on or stepping up to dual exhaust? I have oval vance and hines slip-ons.
Weld it up and run it, these headers are perf engineered well, May want to rmove it to weld it to lower the risk of "cookin" electrical components on bike and keep slag spatter off the bike.
BeauJames
Apr 28, 2014 04:37 PM
Howitt
Nov 12, 2012 07:16 AM
NiteOwl
Jan 30, 2011 09:31 AM
ironhide_uk
Sep 25, 2010 02:34 AM
Scurvy Jack
Mar 18, 2008 11:46 AM
