Cracked Y pipe
Old Jul 15, 2012 | 02:42 PM
14longshot's Avatar
14longshot
Default Cracked Y pipe
The Y pipe on my 08 ultra cracked. What are people doing to fix this are they putting oem parts back on or stepping up to dual exhaust? I have oval vance and hines slip-ons.
Old Jul 15, 2012 | 02:49 PM
Stiggy's Avatar
Stiggy
I welded mine which gave ne time to find the exhaust system that I wanted to try next.
The weld broke just as the new pipes arrived. ( Don't run the bike with the Y pipe cracked or you may be replacing a head after the exhaust valve hangs up.)
Old Jul 15, 2012 | 03:14 PM
1sweetglide08's Avatar
1sweetglide08
I have my stock header pipes from my 08...should be the same for your bike. If you need a new Y pipe you can have mines cheap.
Old Jul 15, 2012 | 03:55 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Now is your chance to get rid of that old header and upgrade to V&H true duals. You will be amazed at how much better you bike will sound....and look!! Do it!
Old Jul 15, 2012 | 04:26 PM
Stiggy's Avatar
Stiggy
And though I run a 2 into 1 now, the true duals make it super easy to keep the rear of the motor and the tranny top clean too!
Old Jul 15, 2012 | 04:56 PM
klaybus's Avatar
klaybus
x2. V&H Dresser Duals here.
Old Jul 15, 2012 | 05:36 PM
nevets61's Avatar
nevets61
Fulsac true duals.....
Old Jul 15, 2012 | 07:37 PM
littled62's Avatar
littled62
also you will want to look at the front motor mount, a lot of times when the y-pipe splits it because the front mount is broke and puts stress on the y-pipe, I welded mine 2 years ago and last year it split at the weld, one of the mech, at the dealer looked at it and showed me the broke mount
Old Jul 15, 2012 | 08:27 PM
Rickey's Avatar
Rickey
Have a local weld shop TIG it up for you.
Old Jul 15, 2012 | 10:49 PM
14longshot's Avatar
14longshot
Been doing some looking and am think of the Fullsac true duals.
Need to talk to a couple of friends to see if they have anything laying around.
I was questioning if a weld would hold? I will defiantly will look at the motor mount.
I'll keep you in mind sweetglide if I go that route.
