Tour Pak lock?
Old Jan 16, 2007 | 01:55 AM
Hiram's Avatar
Hiram
Default Tour Pak lock?
To lock my tour pak I have to lift the lid about a 1/8 inch to allow the latch bar to engage. This does not seem normal to me. I was thinking that I would elongate the holes on the inner lock part so I could drop it down a bit. The Outer lid latch works fine as is so I don't want to move it, just the inside piece. Anybody else have this problem, or is it supposed to be this way?
Old Jan 16, 2007 | 02:17 AM
smknflms's Avatar
smknflms
Default RE: Tour Pak lock?
...yeah, I had to take out screws and just wiggle into a better position, didn't mess with holes. That and a little creative bending and it fits up right. Just visualize where the problem is and move/bend a little to fix.
Later
Old Jan 17, 2007 | 06:31 PM
larry5h's Avatar
larry5h
Yes I have the same problem, sounds like a design problem.
Old Jan 17, 2007 | 11:55 PM
Bubba Zanetti's Avatar
Bubba Zanetti
Just drill some holes in the tour pak, then put a hasp and pad lock on it![sm=lockeddance.gif][sm=icon_rock.gif]
Old Jan 18, 2007 | 01:21 AM
Sharknose's Avatar
Sharknose
ORIGINAL: Hiram
"What do you expect from something that only cost $800??? You should feel luck to have one at all. Jeez, some people...."
---Harley-Davidson
Old Jan 18, 2007 | 01:52 AM
edilgdaor's Avatar
edilgdaor
I have to push down on mine. It wasn't on the bike when I bought it, though, if that counts....
Old Jan 18, 2007 | 08:45 AM
SteelCityScooter's Avatar
SteelCityScooter
ORIGINAL: Hiram
Mine did just the opposite, once closed and locked it would be able to be lifted about an 1/8 to 1/4 inch.
Found the lock tumbler assembly loosened and let the lock asssembly turn just a bit.
Re-aligned and tightened. Alls good.
ORradtech
Jul 26, 2016 06:48 AM
Keithhu
Mar 4, 2013 09:21 PM
Dandy1
Dec 25, 2010 03:13 PM
trigger1911
Jul 11, 2009 09:39 AM
dchoran
May 18, 2008 09:48 AM
